Thread Number: 24557
How to remove these carbon brushes? |
Post# 275152   4/7/2014 at 19:22 (3,668 days old) by beerad (Beautiful Vancouver BC)   |   | |
On this 1957 Filter Queen motor? Does anyone know how to do this? |
Post# 275153 , Reply# 1   4/7/2014 at 19:24 (3,668 days old) by beerad (Beautiful Vancouver BC)   |   | |
View |
Post# 275154 , Reply# 2   4/7/2014 at 19:28 (3,668 days old) by kenkart ()   |   | |
A early 50s, 4250, the 4450 came out on the 500 FQ which was introduced in 55,There should be a screw slot in the end of the brush cap, you just unscrew the cap and pull out the brush. |
Post# 275155 , Reply# 3   4/7/2014 at 19:29 (3,668 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 275157 , Reply# 4   4/7/2014 at 19:30 (3,668 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 275158 , Reply# 5   4/7/2014 at 19:42 (3,668 days old) by kenkart ()   |   | |
That date written on it was when it was serviced, If you peel off the FQ label on the back, the actual date is stamped in the metal. |
Post# 275161 , Reply# 6   4/7/2014 at 19:54 (3,668 days old) by BikerRay (Middle Earth)   |   | |
The screw in the frame above the brushholder just holds the bakelite brushnolder in place. It's like Ken said there should be a brass plug in the bakelite that has a slot in it. You just unscrew that and the brush and spring will come out. Sometimes if the brush is burned you may have to take something and push the brush back through the holder. Be careful around the armature, you don't want to damage any of the segments.
Post# 275170 , Reply# 7   4/7/2014 at 20:06 (3,668 days old) by BikerRay (Middle Earth)   |   | |
