Thread Number: 24410
Balancing a Motor |
Post# 273214   3/24/2014 at 00:25 (3,679 days old) by Jaker15 (Meridian, ID)   |   | |
Hey all. I have a Westinghouse hand vac from the 50's, and it's pretty awesome. The only issue it has is that the motor is pretty off-balance. It seems like the shaft is bent. When it's running, the shaft wobbles and it makes a horrible rattling noise. It kinda bugs me and I'm worried that the wobbling will wear out the bearings prematurely. Is it possible to balance the motor so the shaft doesn't wobble so badly? Thanks so much!
Post# 273218 , Reply# 1   3/24/2014 at 02:52 (3,679 days old) by bnsd60m9200 (Akron OH)   |   | |
NO, and simple and easiest way to remedy the problem, new armature/used from a parts machine. there is way motor winding shops can repair bent armature shafts, but the price is so insaned it's worthless to invest for most people unless motors for that machine simply don't exist anymore
since the commutator is the point where the balance causes problems normally, trying to fix the problem would have a higher chance of the segments exploding inside the motor due to causing the segments to get hairline fractures in the adhesive holding the segments together in trying to straighten the motor shaft back out. |
Post# 273270 , Reply# 2   3/24/2014 at 13:27 (3,678 days old) by Jaker15 (Meridian, ID)   |   | |
I don't know where in the world I'd get a replacement armature, so it's not too big of an issue. I'll just be extra careful in using it from here on out. It seems as though a bent shaft is fairly common in the Westinghouse hand vacs. My friend has almost the exact same model, and he says it has the same problem that mine does, in which the shaft wobbles and it makes that rattling noise. No big deal, I guess it's showing its age! :P
Post# 273485 , Reply# 3   3/26/2014 at 01:57 (3,677 days old) by kirbykid (Horseheads,New York 14845)   |   | |
I have an easy way to fix that, but it appears you don't want any of my help. |
Post# 273528 , Reply# 4   3/26/2014 at 13:37 (3,676 days old) by Jaker15 (Meridian, ID)   |   | |
Post# 273539 , Reply# 5   3/26/2014 at 15:24 (3,676 days old) by Jaker15 (Meridian, ID)   |   | |
