Thread Number: 24355
Arkay vacuum Model #5105 by Apex Electrical |
Post# 272639 , Reply# 1   3/20/2014 at 08:41 (3,688 days old) by Collector2 (Moose Jaw, Sk)   |   | |
Your repair man is full of BS. Its not that hard to remove the ends. Just do it carefully. And make sure you put some tape around the ends of the donor hose before you cut off the other ones so that the woven covering doesn't unravel.
I have the same machine under the Connor name and I changed the hose on it. (I made the kit in the picture incidentally) |
Post# 272924 , Reply# 4   3/21/2014 at 20:42 (3,687 days old) by Collector2 (Moose Jaw, Sk)   |   | |
Hi again
Yep I made the cardboard kit from pictures. The accessory that you asked about is a vaporizer. You put the hose on the exhaust, put moth crystals in the vaporizer and blow the vapour into a closet to kill moths and protect clothing in storage. On the plastic hose, a heat gun used carefully will loosen the solvent. You would probably have to cut the ends off the other one. The picture is a bit small but it could be a premier hose. Doug |
Post# 273640 , Reply# 6   3/27/2014 at 08:36 (3,681 days old) by Collector2 (Moose Jaw, Sk)   |   | |
