Hi, new here, but was wondering if the spring in a model g cord retractor is obtainable, or repairable. Does not pull in and I was about to disassemble again to see if the spring is totally broken of just not wound if that makes sense.
Post# 272136 , Reply# 1   3/16/2014 at 15:04 (3,686 days old) by Paul(USA)
Welcome to Vacuumland. I recently took my Model G to an Aerus dealer. They tightened the spring, and it works just fine now. A cord winder spring is similar to a window shade spring in that it can be loosened with use. And, like a window shade spring, a cord winder spring can wear out; but try having it tightened first. I've been told, though, that it is a risky endeavor; that you can get seriously hurt by a spring if you accidentally release all the tension at once. So you're better off taking it either to an Aerus dealer or a vacuum store if you haven't been trained.
Another tip for helping the cord winder work at top efficiency is to coat the cord with talcum or baby powder.
Well I took it apart and looked at it until I realized how it went together. The spring came off the metal post it clips on. Works great now. I do all my own stunts. I will probably tear down the motor and clean/lube everything. It is so quiet compared to the DJ's I have been using.
