Thread Number: 24144
Royal 2025 brush stops on carpet |
Post# 269967 , Reply# 1   3/2/2014 at 14:01 (3,700 days old) by ornery (Northeast Ohio)   |   | |
Post# 269976 , Reply# 2   3/2/2014 at 15:09 (3,700 days old) by jade_angel (Fort Collins, CO)   |   | |
Sounds like a spindle shaft issue to me too. I'd expect some issues with the fan in that case though. |
Post# 269977 , Reply# 3   3/2/2014 at 15:13 (3,700 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 270005 , Reply# 5   3/2/2014 at 19:46 (3,700 days old) by ornery (Northeast Ohio)   |   | |
Post# 270008 , Reply# 6   3/2/2014 at 20:41 (3,700 days old) by KirbysNphones ()   |   | |
it's a brand new belt, and yes if I let the brush stop for too long, it does stink. I can't stop the brush with my hand (yes I tried to!) |
Post# 270010 , Reply# 7   3/2/2014 at 21:00 (3,700 days old) by pr-21 (Middletown, OH)   |   | |
tipInstallation Tip: There is an arrow on the rug plate as well as an arrow on the brushroll. When installing the brushroll, be sure to align the two arrows.
Maintenance Tip: Most of the brushrolls below have numbers on the endcaps. With a new brushroll, the number 1 on both end caps should face out. As the bristles wear down with use, you should position the brushroll with the next highest number facing out. Doing this will make the bristles stick out further past the rug plate. In your first post you said you had the brush roll at the highest setting, if they are numbers and your brushroll is new it should have #1 facing out and the two arrows on the rug plate and brush roll should point in the same direction. Hope this helps, PR-21 |
Post# 270041 , Reply# 8   3/3/2014 at 03:59 (3,699 days old) by ornery (Northeast Ohio)   |   | |
Post# 270128 , Reply# 10   3/3/2014 at 18:08 (3,699 days old) by ornery (Northeast Ohio)   |   | |
