Thread Number: 24056
Removing a fan blade |
Post# 269104   2/23/2014 at 14:34 (3,713 days old) by cam2s (Nebraska)   |   | |
I'm not sure what happened here, but this needs to come off. Any tips on undoing the bolt? This is from a Panasonic Jet Flo MC-5111 |
Post# 269105 , Reply# 1   2/23/2014 at 14:35 (3,713 days old) by cam2s (Nebraska)   |   | |
The motor... |
Post# 269119 , Reply# 2   2/23/2014 at 17:16 (3,713 days old) by vacman1961 (North Babylon, New York)   |   | |
Did you try turning the nut clockwise, it might be a backwards thread? |
Post# 269125 , Reply# 3   2/23/2014 at 18:41 (3,713 days old) by Anachronism ()   |   | |
Unscrews in the direction the fan turns. Since that fan is toast anyway, pin it down any way you can & tap the wrench handle for the "Impact" wrench effect |
Post# 269132 , Reply# 4   2/23/2014 at 20:00 (3,713 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Grab you some pliers, a ratchet wrench and a good helping of WD-40!
Here's your to-do list:
1-PIN down the pliers onto the motor's extruding metal rod thingy (Where the belt goes, the "Spindle", if you will!).
2-SPRAY a sufficient amount of WD-40 penetrating spray into and around the nut. this will penetrate into the nut and help to free it easily.
3-WRENCH the nut off with the ratcheting wrench.
This should VERY easily help with the removal of the nut. if this fails and you have a blow-torch, you can heat the nut up after wiping off the WD-40. This will expand the nut and thus make it more willing to remove.
