My Electrolux 1205 needs a new front bearing. It just recently started to howl and I would like to replace it before it wears out completely. Does anyone know the bearing number, so I can purchase it from a bearing shop? I know the front bearing is the issue, because I recently took the motor out and lubed the rear sleeve bearing. Thanks.
you need is a 38 mm bearing . Common bearing used on lamb motors as well. If it had been a XXX or LX it would have been a 37mm and 39mm.I hope this helps.
