Thread Number: 23439
kirby heritage tear down trouble shoot |
Post# 262467 , Reply# 1   1/8/2014 at 18:08 (3,754 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Pictures would help. I sell heritage motors so if you need a new one i could send you a rebuilt power plant |
Post# 262468 , Reply# 2   1/8/2014 at 18:08 (3,754 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Alright, There a number of thing that could have gone wrong, but we'll need some specifics other than "won't turn on"!
Does it hum, the light turn on, or anything? Let's list some possibilities, shall we?
Humming indicates you've frozen the motor (The motor cannot freely spin). You could have done this by not fully tightening a screw, causing the fan to hang on it (Or some other rotating motor part).
If the light is coming on, You've likely messed something up with the speed switch. I'd take it apart and look for lose wires, broken contacts, Etc.
I'm guessing you're referring to the Original Heritage I of 1981-1984, But in the event it is a Heritage II (Grey bag with black), You'll notice a Red light on the top of the power plant (Motor). If this light is illuminated, You have power to the cleaner. I suppose you could take an Ohm meter to where the cord plugs into the cleaner to test for broken electrical contacts.
Have fun! |
Post# 262473 , Reply# 4   1/8/2014 at 18:27 (3,754 days old) by vacuumssuck213 ()   |   | |
It is a 82 HD 1 if that helps |
Post# 262476 , Reply# 5   1/8/2014 at 18:34 (3,754 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 262479 , Reply# 6   1/8/2014 at 18:44 (3,754 days old) by vacuumssuck213 ()   |   | |
If worse came to worse how much do you charge for a rebuilt ? |
Post# 262489 , Reply# 7   1/8/2014 at 20:52 (3,754 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 262501 , Reply# 8   1/8/2014 at 21:16 (3,754 days old) by Craig_1982 (Newcastle Under Lyme (England))   |   | |
when you say the shell of the motor, do you mean the actual metal outer casing? (shouldn't stop the machine) or you mean as in the casing surrounding the motor armature and field coil? (white in colour held in by 4 screws)
if it was the latter when you put it back together again, were the carbon brushes put in correctly sometimes these don't quite make contact on the armature. Also as Alex said above it could be the speed switch as well, make sure the wires are fully connected and in the corresponding colour slot and check the mechanisms working correctly. |
Post# 262502 , Reply# 9   1/8/2014 at 21:24 (3,754 days old) by Craig_1982 (Newcastle Under Lyme (England))   |   | |
Post# 262507 , Reply# 10   1/8/2014 at 21:46 (3,754 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Its 30 bucks for a rebuilt power plant. That's just a rebuilt motor, not polished. Its 75 bucks if you want it polished. |
Post# 262570 , Reply# 11   1/9/2014 at 11:29 (3,753 days old) by vacuumssuck213 ()   |   | |
I will try to tear into again later in the week if not next would hate to think one of my babies won't run again. Or for awhile at best |
Post# 262676 , Reply# 12   1/10/2014 at 11:59 (3,752 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 263159 , Reply# 14   1/13/2014 at 09:50 (3,749 days old) by Craig_1982 (Newcastle Under Lyme (England))   |   | |
Have you tried knocking them round? if you get a small flat bladed chisel tap a wedge into the screw head then try knocking it around to free it off this sometimes work. There's other ways too first you can try drilling a small hole in the middle of the screw sometimes it releases enough pressure for you to be able to turn the screws, you can also try both, small hole drill then trying knocking the screw around with a chisel sometimes it work's and saves you on re-tapping the threads.
Another option is If your replacing the screws with the same size screws then you will need to drill out the whole diameter of the screw. If any of the screws can come out then remove one and match it up to a metal drill bit as I'm not sure exactly what diameter they are, Also measure the depth of the screw to the drill bit as you don't want to drill any deeper, I usually put some tape on the drill bit so I know when I'v reached the desired depth, The next step you will need a Tap&Die tool set, this is used to recreate a thread in the casing ready for the new screws to be inserted, Make sure again you get the right diameter tool. These process do work done it with two Kirby's in the past as long as you drill straight and you get the right diameters then you should be ok. Here's a you tube video to show you about tap and die.. |
Post# 263208 , Reply# 15   1/13/2014 at 17:10 (3,749 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 263211 , Reply# 16   1/13/2014 at 17:35 (3,749 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 283925 , Reply# 18   6/10/2014 at 00:54 (3,602 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Nathan,
Here's this page of the Heritage II service manual to help you. ~Ben |
Post# 283962 , Reply# 19   6/10/2014 at 11:34 (3,601 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
