Thread Number: 23239
Hoover Celebrity QS |
Post# 260284   12/20/2013 at 23:09 (3,751 days old) by stricklybojack (Southern California)   |   | |
Post# 260285 , Reply# 1   12/20/2013 at 23:13 (3,751 days old) by stricklybojack (Southern California)   |   | |
Post# 260292 , Reply# 2   12/21/2013 at 01:33 (3,751 days old) by opelgtkarl (Puyallup, Washington)   |   | |
That is certainly a machine that will make everyone green with envy! I had one just like this, but it was missing everything including the hose and power nozzle. I wish I had a complete one though. Its always good to see something different. :)
-Karl CLICK HERE TO GO TO opelgtkarl's LINK |
Post# 260293 , Reply# 3   12/21/2013 at 01:34 (3,751 days old) by opelgtkarl (Puyallup, Washington)   |   | |
Post# 260324 , Reply# 4   12/21/2013 at 15:41 (3,750 days old) by Durango159 (State College, PA)   |   | |
Post# 260512 , Reply# 7   12/23/2013 at 13:58 (3,748 days old) by HooverCelebrity (Germany)   |   | |
As I sit here thinking about it, you may not even need to remove the white motor cover at all. The "acorn" nuts may be visible by just removing the bag. I don't have a Celebrity handy at the moment to confirm that, however. |
Post# 260522 , Reply# 8   12/23/2013 at 16:36 (3,748 days old) by alexb1186 (Ferguson/St. Louis, MO)   |   | |
Post# 260558 , Reply# 9   12/23/2013 at 20:27 (3,748 days old) by stricklybojack (Southern California)   |   | |
Post# 260586 , Reply# 10   12/23/2013 at 23:20 (3,748 days old) by Durango159 (State College, PA)   |   | |
Fred is absolutely correct about the sound insulation. I have replaced this on a few machines. I tried Lowe's and Ace Hardware and they recommended me to Joann Fabric. I was shocked but at Joann fabric you can foam by size. I bought about 1 yard of green approx. 3/4" thick breathable foam. I have replaced the foam insulation on 4 Celebrity's now with that same piece, so you don't even need a full yard, you would do fine with ordering about a half yard. It's only a couple of dollars then just cut it approximately to size and fit in. I think I stuck it through the metal posts for the screws. I didn't use any glue or any sort of adhesive, the foam is thick enough to hold in place just where the layout in the metal bottom plate is for it. Very simple repair that will take you 10 minutes most likely, then you won't be chasing any more dust around your home!!
Terrific luck with your machine. Happy Holidays and Happy New Year to all!! |
