Thread Number: 23172
Question model 62 and 115 Junior
Post# 259386   12/13/2013 at 15:19 (3,785 days old) by dutchjim ()
I've been researching the old threads here, and I can't understand a couple of things.
hoover1060 in Post# 12662 said "...model 62, and the cheapie 115 Junior. It was basically a model 62 minus the handle grip and handisac bag." So, are the motor parts interchangeable? And, is the same also true for model 29?
Are the carbon brushes for the Convertible the same as model 62?
Last question: The information from the threads is that I can use belts for the Convertible on my model 62, but they should be old belts that have been stretched and worn in. So, I need a couple of belts for my 62. Should I ask people at Vacuumlad for their old Convertible belts?
Thank you for your patience. -Jim
Post# 259399 , Reply# 1   12/13/2013 at 18:30 (3,784 days old) by hooversrus ()
Hey
The carbon brushes are same. For belts I never had a problem with using a new hoover convertible belt but if your concerned about it being to tight just get a couple eureka belts
Post# 259524 , Reply# 2   12/14/2013 at 21:10 (3,783 days old) by dutchjim ()
Hey
Hey Travis, thanks for the -Jim
Post# 459108 , Reply# 3   1/2/2023 at 17:39 (477 days old) by draarc (Oreland Pa)
hoover model 62 belt and brushes
I need a replacement belt for my hoover model 62 . the original belt was 4 5/8" in diameter and approximately 14" circumference. A convertible belt is to tight and cracked the roller brush found a replacement roller brush but need the correct belt. could anyone direct me too the right replacement belt, also could use new brushes
Post# 459118 , Reply# 4   1/2/2023 at 22:28 (477 days old) by hoover28 (Oneida N.Y.)
Hoover belt
Hoover belt for a model 62 is a part number 44783
