Thread Number: 22991
Hoover Aria - HELP! |
Post# 257362 , Reply# 1   11/23/2013 at 08:51 (3,804 days old) by RootCyclone (East Midlands,UK.)   |   | |
The wires in from the mains (UK - 230-260V AC 49.9 - 50.1Hz). For those who don't know, the Brown is the LIVE and the Blue is the NEUTRAL |
Post# 257383 , Reply# 5   11/23/2013 at 13:56 (3,804 days old) by RootCyclone (East Midlands,UK.)   |   | |
So the circular what I called 'odd shaped component' is the thermal cut out then? yes?
I preferably want to wire it up as it was just without the re-wind being there, basically still using the switch, suppressor and all other bits n' pieces that still work fine. |
Post# 257388 , Reply# 6   11/23/2013 at 14:23 (3,804 days old) by vintagerepairer (England)   |   | |
Hello. Where did you say that? |
Post# 257389 , Reply# 7   11/23/2013 at 14:30 (3,804 days old) by RootCyclone (East Midlands,UK.)   |   | |
bollocks, I didn't say that. Urgh! tiredness again as well as trying to get the Aria to work! :(
Just look at reply #2 for the circular odd looking component picture, is that the thermal cut out? |
Post# 257390 , Reply# 8   11/23/2013 at 14:33 (3,804 days old) by vintagerepairer (England)   |   | |
Yes, that is it. What you have removed (the coil) was attached to the two wires for the motor. All you need to connect those to the incoming mains supply. |
Post# 257401 , Reply# 11   11/23/2013 at 15:53 (3,804 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Ah so live to switch only, neutral through the thermal cutout |
