Thread Number: 22838
Hoover Convertible Update |
Post# 255414 , Reply# 1   11/6/2013 at 17:09 (3,794 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 255418 , Reply# 2   11/6/2013 at 18:14 (3,794 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
You're a Hood.
(No offensive, But do you see what I did there?)
You can wash that bag in mildly warm soapy water, You can use a rag to remove excess Schmutz/Dirt, rinse in warm water. Don't even try putting it in a washing machine, It's not even recommended to use the washing machine of cloth-bag units. The same would go for the trim and plastics (Except the HOOD, John apparently knows a thing-or-two about them)!
It you're "Experienced", and looking to completely overhaul you new Hoover, You could go for the motor. taking it apart and washing ONLY the plastics. You'll find the middle part of the motor shell has part of the magnetic field generation thingy, What ever it is called, is permanently attached to the motor. You could use a dis-infection wipe for that. Be careful with the motor, DO NOT grip the armature with pliers to remove the fan, I ruined a perfectly good armature and learned that the hard way.
And yes, I have a YouTube channel for vacuums, Vacguy99.
Good luck, And Happy Hoovering! -Alex. |
Post# 255422 , Reply# 3   11/6/2013 at 19:26 (3,794 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Alex, why would you not want to run the entire motor through the dish washer? Ive run hundreds of kirby motors through the dish washer and they come out just fine. Is there a difference in material the motor is made of that would cause it to not run normal or not run at all? |
Post# 255429 , Reply# 4   11/6/2013 at 22:02 (3,794 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 255546 , Reply# 5   11/7/2013 at 17:11 (3,793 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
