Thread Number: 22696
Part Numbers Wanted for Kirby "Mark V" Handi-Butler |
Post# 253628   10/23/2013 at 13:03 (3,835 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Does anyone with a large knowledge of Kirby information post-Sanitronic VII know anything about part numbers for the "Mark V" Handi-Butler (no Handi-Sharpener or wire wheels) used on the Classic III, Tradition and Heritage, especially the jig saw accessory and blades?
To get this ball rolling, here is all the HB part numbers I know (please feel free to correct me if necessary): 141279S - speed switch connector pin (early Tradition) 400073 - HB body shell (Classic Omega, Classic III, Tradition) 400081 - HB body shell (Heritage) 402376S - HB jack shaft spindle 402558 - HB jack shaft end cover 4027 - HB pulley lock pin 404076S - HB body cover, red (Classic III) 404079S - HB body cover, blue (Tradition) 404081S - HB body cover, gray (Heritage) 405058 - HB belt 408076 - HB assembly screw 412062S - HB rubber disc assembly 412662S - HB sandpaper, set of 3 4140 - HB lamb's wool pad 419058 - HB wrench 420062S - HB flannel buffing wheel, soft 422062S- HB sewn buffing wheel, hard 4240 - HB polishing stick, coarse 4260 - HB polishing stick, fine 427062 - HB drill chuck 428076S - HB wheel cup stands, red (Classic III) 428079S - HB wheel cup stands, blue (Tradition) 428081S - HB wheel cup stands, gray (Heritage) 417460 - Flexible shaft core 417560 - Flexible shaft spindle, 1/2" 417676 - Flexible shaft casing, red (Classic III) 417679 - Flexible shaft casing, blue (Tradition) 417681 - Flexible shaft casing, gray (Heritage) 418160 - Flexible shaft nut, 1/2", RH Thank you, Ben |
Post# 253798 , Reply# 1   10/24/2013 at 16:11 (3,834 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 253799 , Reply# 2   10/24/2013 at 16:13 (3,834 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 324748 , Reply# 3   5/13/2015 at 02:57 (3,269 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Update:
K141279 - speed switch connector pin (early Tradition) K400076S - HB frame and bearing assembly (all) K402362S - HB jack shaft spindle (all) K402458 - HB jack shaft pulley (all) K402558 - HB jack shaft end cover (all) K4027 - HB pulley lock pin (all) K404076S - HB body and belt lifter assembly, red (Classic III) K404079S - HB body and belt lifter assembly, blue (Tradition) K404081S - HB body and belt lifter assembly, gray (Heritage) K405058 - HB belt (all) K408076 - HB assembly screw (all) K412076S - HB rubber disc assembly, red (Classic III) K412079S - HB rubber disc assembly, blue (Classic III) K412081S - HB rubber disc assembly, gray (Heritage) K412662S - HB sandpaper, set of 3 (all) K414073 - HB lambswool pad (all) K420062S - HB flannel buffing wheel, soft (all) K422062S- HB sewn buffing wheel, hard (all) K4240 - HB polishing stick, coarse (all) K4260 - HB polishing stick, fine (all) K427062 - HB drill chuck (all) K427176 - HB drill chuck adapter (all) K427377S - HB saber saw and adapter assembly, black (Classic III/Tradition) K427476S - HB saber saw blades, set of 2 (Classic III/Tradition) K428076S - HB wheel cup stands, red (Classic III) K428079S - HB wheel cup stands, blue (Tradition) K428081S - HB wheel cup stands, gray (Heritage) M417176S - HB flexible shaft assembly, red (Classic III) M417179S - HB flexible shaft assembly, blue (Tradition) M417181S - HB flexible shaft assembly, gray (Heritage) ~Ben |
