Thread Number: 22670
Sentria II Dilemma |
Post# 253332   10/20/2013 at 03:33 (3,840 days old) by jkbff (Dickinson, ND)   |   | |
Well.. If you guys recall I had purchased a Sentria II for my mother last year for her birthday... Well, she has done nothing but complain about it since I got it for her...
Let me start this by saying She loves Kirby's and won't have anything but a Kirby... I tried my hardest to talk her out of it but she wouldn't listen... So I purchased it. She has a sculptured carpet... The vacuum ratchets when she vacuums... What I mean by that is if you watch the fork from the transmission to the pivot as it goes forwards and back, as it hit a divot in the carpet, the transmission is pushing forward, jolts because of the divot, the pivot pushes the fork to neutral, but the vacuum is still propelling forward and so the fork slams into forward again, repeating the process multiple times per second... Making the transmission ratchet... One would think this wouldn't be that big of a deal.. Change vacuuming speeds or angles or something... But the jolt of the handle being slammed/ratcheted combined with the fact that my mother is getting older and her skin isn't like what it used to be, she is getting bruised when she uses her vacuum... She had a G3 that she got rid of when I got this for her, the G3 didn't ratchet because the transmission wasn't as sensitive, it had more of a gap from the forward distance to the neutral position to the reverse... It didn't have the center slide plate that had a self centering spring. (I am very tempted to put a g3 slide plate in the Sentria II!) Also, the seal on the nozzle was worn to the metal so it didn't gasp for air when it hit the divots of the carpet... I've tried monkeying with the forward position and the reverse set screws, have gotten it to where it doesn't spin the gears when its in neutral and doesn't ratchet *as* much in drive, but I don't think this will last long or things will function properly set this way... I don't want to be stuck with a vacuum that I DO NOT want (aside from the fact I have a new transmission coming in case I have to sell this machine but I already have 3 machines on hand). Do you guys have any suggestions on what I can do to make this machine more comfortable for her to vacuum with? Here is a pic of the carpet... It is evil.. From Requested Vac Pics |
Post# 253337 , Reply# 1   10/20/2013 at 07:02 (3,840 days old) by ncovert (Grove City, PA)   |   | |
Try to modify it and put the spring assembly from the Generation 3 into the Sentria II, but beware that the SEII tranny is a bit slower running than the G3's. You might just want to try and swap the whole transmission! |
Post# 253363 , Reply# 2   10/20/2013 at 13:44 (3,839 days old) by jkbff (Dickinson, ND)   |   | |
When I go over there today, I'm gonna take the centering spring off of the plate and see if I can adjust a bit more of a forward gap... after that I'm gonna see if I can find a g3 tranny and slide to put in it...
I rebuilt a g3 for her but you can tell she's upset about going from something brand new to something so old.. It ratchets too because the nozzle seal is brand new so it gasps for air and makes the vacuum jump.. When I was monkeying with the tranny last night, I did start to get a whine from it, but it had been runnung for a long time as I messed with the set screws on the plate and the back of the tranny while it was in neutral ... I'm hoping it was just warm and I didn't mess anything up beyond repair.. I wonder how far I can go before it does break... |
Post# 253394 , Reply# 3   10/20/2013 at 23:05 (3,839 days old) by Kirbysthebest (Midwest)   |   | |
Have it looked at under warranty. Maybe there is an adjustment they can make. |
Post# 253396 , Reply# 4   10/21/2013 at 00:29 (3,839 days old) by jkbff (Dickinson, ND)   |   | |
Post# 253404 , Reply# 5   10/21/2013 at 07:34 (3,839 days old) by ncovert (Grove City, PA)   |   | |
Try the brush roll for delicate carpeting, available from Kirby's website or your local distributor... |
Post# 253573 , Reply# 6   10/22/2013 at 23:27 (3,837 days old) by adambomb (Undisclosed )   |   | |
I had a similar problem with my Sentria II. It got to wear it would hop on the carpet. I applied some fresh grease the the rear axle. Helped tremendously and works like it should. It glides on the carept and doesn't hop or ratchet. |
Post# 253711 , Reply# 7   10/24/2013 at 01:08 (3,836 days old) by jkbff (Dickinson, ND)   |   | |
