Thread Number: 22607
filter queen wiring |
Post# 252692   10/12/2013 at 13:06 (3,842 days old) by lynnster ()   |   | |
I have a filter queen 33 with dual speed. My kid took apart the machine along with the wiring. Can't get them back correctly. Please HELP!! Lynn |
Post# 252723 , Reply# 1   10/12/2013 at 16:42 (3,842 days old) by dysonman1 (the county)   |   | |
The two speed switch has four color wires (red, white, blue, yellow). The motor has five wires (red, white, blue, yellow and black). The switch has two black wires. The cord has one black and one white wire. If you have a power nozzle receptacle, it also has two black wires.
First, join the white 2 speed switch wire to the white motor wire. Second, join the blue 2 speed switch wire to the blue motor wire. Third, join the yellow two speed switch wire to the yellow motor wire. Forth, join the red 2 speed switch wire to the red motor and the white cord wire. (if you have a power nozzle receptacle, join one black wire to the above). Fifth, join the black motor wire to the black switch wire (if you have a power nozzle receptacle, join the remaining black wire to the above) Six, join the remaining black switch wire to the remaining black cord wire. That's it. If you have a power nozzle receptacle, three of your wire connectors are larger than the other. The smaller wire connectors are used with the 2 wire connection, the larger connectors are used with the connections of 3 or more wires. The largest wire connector (wire nut) is used with the Forth connection. For any single speed vacuum, the connections are as follows: One cord wire to one switch wire One motor wire to one switch wire One motor wire to one cord wire |
Post# 252827 , Reply# 2   10/13/2013 at 15:02 (3,841 days old) by d-jones (Pittsburgh)   |   | |
I had my sisters model 33 apart for a dual bearing change and took this photo of the wiring at the time. I hope it helps. |
Post# 252828 , Reply# 3   10/13/2013 at 15:06 (3,841 days old) by d-jones (Pittsburgh)   |   | |
The wiring in the photo above matches Tom's instructions nicely. |
Post# 252830 , Reply# 4   10/13/2013 at 15:58 (3,841 days old) by dysonman1 (the county)   |   | |
Post# 355652 , Reply# 6   7/8/2016 at 11:28 (2,842 days old) by kenkart ()   |   | |
Or Clay Floyd tells you how to fix something, you can COUNT on it! |
Post# 355673 , Reply# 7   7/8/2016 at 16:55 (2,842 days old) by human (Pines of Carolina)   |   | |
That's one of the main things I like about my FQ. It may not be my favorite vac but the wiring is dead simple with not a circuit board (aka self-destruct mechanism) in sight. Even better, all connections are made with conventional wire nuts. The bottom line is it's actually designed to be worked on.
