Thread Number: 22182
Miracle Mate death and upgrade |
Post# 248906 , Reply# 1   9/3/2013 at 06:06 (3,859 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Michael, I would suggest using the Ametek motor over the Domel motor. Domel motors, although good, in my opinion & experience aren't quite as durable & long-lasting as Ametek motors are. But then again, they are manufactured in Slovenia, so that accounts for the difference in quality between the brands.
Another problem is that the Domel motor appears to be a central vac motor, judging by it's waterlift, airflow & amperage ratings. If you were to install this motor in a normal vacuum, I would think the combined amperage of the motor & powerhead motor running might be enough to trip a breaker or blow a fuse in your home. The Ametek motor you are also interested in happens to be a replacement Miele motor, & pulls 100" waterlift....so you should be more than satisfied with it's performance without risking the safety of your home's wiring. Good luck....Rob PS- When you say the motor died, have you checked the carbon brushes? Before you go about replacing the motor, I would check them first, & if worn down, replace them. This is most likely the cause of the issue with the Miracle Mate's motor, given the age of the vacuum & the life expectancy those motors are expected to last under household usage. |
Post# 248909 , Reply# 2   9/3/2013 at 06:57 (3,859 days old) by MiracleMateV8 ()   |   | |
I already looked at the brucshes there is about 50% left on the brushes |
Post# 248910 , Reply# 3   9/3/2013 at 07:02 (3,859 days old) by MiracleMateV8 ()   |   | |
also I use it to clean abig house with pn combined little over 16 amps Just make it is plugged in to 20 amp circuit |
Post# 248948 , Reply# 4   9/3/2013 at 10:53 (3,859 days old) by MiracleMateV8 ()   |   | |
Well thast what I want to do. |
Post# 249120 , Reply# 5   9/4/2013 at 20:20 (3,857 days old) by MiracleMateV8 ()   |   | |
will 14/3 be plenty for 16 amps of power |
