Thread Number: 22147
Kirby Fan Case Rebuild |
Post# 248418   8/30/2013 at 17:47 (3,885 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Has anyone familiar with replacing gaskets on models 562 through G4 ever known how to install a new O-ring gasket (122068)?
My dad recently did so on my Classic III 2CB. However, my concerns are these: 1 - after successful installation of the new gasket, do you really have to wait at least 24 hours from the time of the installation before next use of the vacuum? 2 - while allowing the sealant for the gasket to cure, should I have the rug nozzle or hose installed on it to hold the newly-installed gasket for the 24-hour-long duration? ~Ben |
Post# 248528 , Reply# 2   8/31/2013 at 18:29 (3,883 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Charlie,
It was #T106 that you refer to as the plastic sealer Kirby had used. Anyway, today I just ran my Classic III, and with the hose on it, I finally got it to run fast again. The new fan case gasket obviously makes a better seal than a worn out one in this case. But I remain concerned about premature gasket wear so soon. ~Ben |
Post# 248547 , Reply# 4   9/1/2013 at 00:08 (3,883 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 248555 , Reply# 5   9/1/2013 at 03:25 (3,883 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Charlie....by any chance, are you referring to a special type of brown rubber cement called Pliobond? That's what our former vac shop used for Kirby seals & anything in which a foam or rubber seal had to be attached. Worked great, I actually use it myself now as it can be obtained easily in most hardware stores.
Rob |
