Thread Number: 21969
ADVICE FOR MY KIRBY 516 |
Post# 246303 , Reply# 1   8/17/2013 at 20:55 (3,897 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
J,
If the brush roll you used has stiffeners (I presume it doesn't), then that buzzing sound is normal. I also believe there may be hair wrapped up around the end caps; those should be cleaned off. The brush roll will only fit one way: the white cap should face your right when the nozzle is viewed up front. ~Ben |
Post# 246315 , Reply# 3   8/17/2013 at 21:37 (3,897 days old) by kirbykid (Horseheads,New York 14845)   |   | |
This happens with my royal. I think the brush roll is just loose. i dont know how you could fix that but i think thats the problem. |
Post# 246331 , Reply# 4   8/17/2013 at 23:00 (3,897 days old) by adambomb (Undisclosed )   |   | |
The belt lifter may be rubbing up agaisnt the motor shaft pulley. |
