Thread Number: 21904
Problem with Royal 9000 roller |
Post# 245438 , Reply# 1   8/12/2013 at 20:58 (3,902 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 245490 , Reply# 2   8/13/2013 at 08:59 (3,901 days old) by SamBurritos ()   |   | |
Thanks! |
Post# 245569 , Reply# 3   8/13/2013 at 19:30 (3,901 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
If the belt isn't the cause of your troubles, before you throw the brushroll away try removing the end-caps & see if any hair or string is built up around there. That is what will cause a brush not to turn & ruin your bearings. That, & a bit of 3 in 1 oil will probably restore your brushroll to good working order. And of course, make sure you check your brushroll for strings, threads & hair after every vacuuming session, & check the endcaps once a month for buildup.
Rob |
