Thread Number: 21755
Nasty vacs in for repair |
Post# 243338 , Reply# 1   8/2/2013 at 08:53 (3,917 days old) by ncovert (Grove City, PA)   |   | |
Are these washable? I don't think so. |
Post# 243340 , Reply# 2   8/2/2013 at 08:54 (3,917 days old) by ncovert (Grove City, PA)   |   | |
Still smell a bit like dog. |
Post# 243347 , Reply# 3   8/2/2013 at 09:56 (3,917 days old) by vegassucks ()   |   | |
The mess of Bagless is why I did not keep my Dyson for very long. |
Post# 243355 , Reply# 4   8/2/2013 at 15:50 (3,917 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Halfway through a dyson strip down now, bagless is cleaner (unless its been used with a burst bag) |
Post# 243379 , Reply# 5   8/2/2013 at 20:51 (3,916 days old) by myles_v (Fredericksburg, VA)   |   | |
Post# 243380 , Reply# 6   8/2/2013 at 20:56 (3,916 days old) by ncovert (Grove City, PA)   |   | |
Thank you for the tip, Myles!
Unfortunately the machine sounds a bit off, maybe needs a new brush roll.
The Bissell just had a little clog that was easily fixed. |
Post# 243382 , Reply# 7   8/2/2013 at 21:03 (3,916 days old) by myles_v (Fredericksburg, VA)   |   | |
You're welcome!
What does it sound like? Try cleaning the brush roll before buying a new one, as that can help with brush roll sounds. My Dirt Devil Handi-Vac sounded odd so I took it apart and the problem was that hair had gotten wrapped around the motor shaft behind the fan and it had made its way into the motor compartment itself. I cleaned that out and dusted the whole motor off and it is much quieter now. I'm pretty sure that Hoover uses a bypass system but it shouldn't hurt to clean out the motor compartment anyways. |
Post# 243390 , Reply# 8   8/2/2013 at 21:36 (3,916 days old) by Durango159 (State College, PA)   |   | |
Those machines actually are fairly good with performance. I've refurbished and resold a few of each kind over the years.
That Hoover Bagless, which I believe is model number: U5280-940 would have the 7.3Amp motor. Hoover did switch the 12Amp motor at some point but as best I can make out decals, I'd say yours is still the nice energy efficient model. That Hoover is a Direct Air- fan first system, not a clean air design. You need to check the fan chamber on motor and make sure all blades are intact. The brush rolls on these are awesome because they are completely serviceable. Unless those bristles are worn or anything is melted, then everything is fixable. Bearings can be cleaned, greased or replaced if real bad. Remove all hair on bristles and under end caps. If end caps show any melting- they can be replaced. Upon reassembly ensure that metal washer on each end is installed correctly, brush roll should rotate smoothly, quiet and fast. If not recheck everything again. You're better off trying to keep the genuine style plastic/ with nylon bristle agitator than ruining this vac with a wooden CWP yellow bristled vacuum. There is a HUGE HUGE cleaning difference in using the yellow bristled CWP brush rolls compared to original style Hoover ones. Hoover would not recommend washing that filter, but myself along with some others have done it. Just be careful and don't soak any longer for 30 minutes if even that long. You'd be amazed what 10 minutes in bleach will do!! I hate bleach but for those filters, it works awesome. Those Bissells are fairly basic to work on. Clean air designs, 12 Amp motors. I recommend washing hose. If you do wash the hose hang it dry for about 36 hours to ensure its completely dry before re-installation. Hardest part about those Bissells in my mind is the housing behind the dirt cup as there are tons of miniature compartments that collect all sorts of dust and junk. Best of luck and keep us informed of any questions, concerns and updates!!! |
Post# 243393 , Reply# 9   8/2/2013 at 21:54 (3,916 days old) by ncovert (Grove City, PA)   |   | |
The Bagless is a U5280. I completely tore it down and scrubbed every plastic piece clean. All the impeller blades are there and the fan chamber is intact. You said it has a 7.3A motor, but on the motor tag it says 6.9A, maybe just an approximation? |
Post# 243432 , Reply# 10   8/2/2013 at 23:47 (3,916 days old) by Durango159 (State College, PA)   |   | |
Post# 243453 , Reply# 11   8/3/2013 at 00:35 (3,916 days old) by myles_v (Fredericksburg, VA)   |   | |
Post# 243500 , Reply# 12   8/3/2013 at 09:51 (3,916 days old) by ncovert (Grove City, PA)   |   | |
...It is all chewed up and both end-caps are cracked. Sorry for the fuzzy pic, my camera sucks. |
Post# 243501 , Reply# 13   8/3/2013 at 09:52 (3,916 days old) by ncovert (Grove City, PA)   |   | |
I'll have to see if my neighbor wants to invest in a $25 brushroll. |
Post# 243503 , Reply# 14   8/3/2013 at 09:53 (3,916 days old) by ncovert (Grove City, PA)   |   | |
I'm beginning to wonder if a dog got ahold of it... Most likely not :p |
Post# 243515 , Reply# 15   8/3/2013 at 10:29 (3,916 days old) by gsheen (Cape Town South Africa)   |   | |
Post# 245463 , Reply# 17   8/13/2013 at 02:57 (3,906 days old) by cb123 (Mobile, Al.)   |   | |
