Thread Number: 21503
grey Electrolux Epic 6500SR issues |
Post# 240746 , Reply# 1   7/18/2013 at 07:27 (3,928 days old) by kirbykid63 (Wilmington Delaware)   |   | |
The wand on the hose has a loose connection,dissasemble the wand and see if the contacts are bent broken,or dirty.Remove screws and the two pieces separate off the hose.The wand is replacable if you cant fix it. Richard Groski new2youvacuums on eBay. |
Post# 270531 , Reply# 2   3/6/2014 at 21:43 (3,696 days old) by floor-a-matic (somewhere)   |   | |
Now the Epic 6500 shuts off when I put the tool against any surface (ex: dusting) What could the problem be?
Post# 270548 , Reply# 3   3/7/2014 at 00:21 (3,696 days old) by bimmer740 (Long Island, New York)   |   | |
I had they same grey 6500SR for many years that I bought from a Kirby dealer from his trade ins. I think I paid less the $100 for the both a 6500 and matching 3500SR upright, both in excellent cosmetic condition. The upright was mechanically perfect but the canister was another story. I don't know what the previous owner did to it but the motor needed to be completely rebuilt. It wasn't that old at the time, maybe 7-8 years old but it had problems. Anyway, it wasn't that costly at the time to rebuild the motor and after it was rebuilt it ran perfectly for years afterwards.
Have you checked the connections for the hose at both the machine and wand end? The bag door has 4 small screws in it and that will allow you to see it there is a problem with the connection at the machine end. The hose handle should come apart easily too, the metal contacts in the handle press against a contact on the hose and may be damaged or dirty. As for your cord winder, if it's not working just buy a new one. Don't try and fix it, the metal coil inside is very sharp and very dangerous. I can tell you this from experience, it's not worth going near it. |
Post# 270552 , Reply# 4   3/7/2014 at 01:57 (3,696 days old) by pr-21 (Middletown, OH)   |   | |
