Thread Number: 21416
Could you help me with my Electrolux model V motor |
Post# 239643 , Reply# 1   7/10/2013 at 13:42 (3,942 days old) by markus79 (Finland)   |   | |
Should I put some oil in this hole? |
Post# 239644 , Reply# 2   7/10/2013 at 13:44 (3,942 days old) by markus79 (Finland)   |   | |
How about this? |
Post# 239645 , Reply# 3   7/10/2013 at 13:45 (3,942 days old) by markus79 (Finland)   |   | |
Is there bearings or what? |
Post# 239646 , Reply# 4   7/10/2013 at 13:46 (3,942 days old) by markus79 (Finland)   |   | |
Carbon brushes are ok |
Post# 239648 , Reply# 5   7/10/2013 at 13:47 (3,942 days old) by Electrolux137 (Los Angeles)   |   | |
Yes, the hole is for oiling. You don't actually need to remove the motor to access it. There's a small spring-loaded "button" on the motor housing under the handle. The button is on top of that narrow brass tube you're holding in your fingers. The wick in your photo should go into that tube (not down into the commutator). Press the tip of your oil can against the button to open it and dispense some oil. Do not overdo it -- just add a few drops at a time, then run the motor a little bit, then a few more drops if it still seems sluggish or sounds dry. I hope this is clear and makes sense...! |
Post# 239649 , Reply# 6   7/10/2013 at 13:47 (3,942 days old) by markus79 (Finland)   |   | |
There is even a motor filter or some kind of antibacterial filter |
Post# 239650 , Reply# 7   7/10/2013 at 13:50 (3,942 days old) by markus79 (Finland)   |   | |
type plate, does anyone know when this is made? |
