Thread Number: 21375
Kirby vacuum Micro-Matic problem |
Post# 239197 , Reply# 1   7/6/2013 at 17:42 (3,917 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 239198 , Reply# 2   7/6/2013 at 18:00 (3,917 days old) by ncovert (Grove City, PA)   |   | |
I tried that, and it still slipped from 8 to the bottom. |
Post# 239202 , Reply# 3   7/6/2013 at 19:12 (3,917 days old) by vacfanatic (Omaha, NE)   |   | |
Post# 239223 , Reply# 4   7/6/2013 at 23:55 (3,917 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
The Kirby Heritage II service manual says this:
a. "If front bracket shaft (131684S, 131687S or 131688S depending on model) needs service, remove two clamp screws (134157S) from bottom of fan case and allow free end of shaft to fall away from fan case. Ratchet end of shaft can now be lifted away from ratchet lock (133073G) and spring (1331S)." b. "If ratchet lock mechanism is too stiff or tight, you should disassemble and grease both the ratchet plunger and ratchet gear teeth. Also, repeated operation will break-in assembly for easier use. If you do not have extra ratchet locks in stock, you may try switching from other units to achieve a better match for smooth operation." c. "To assemble front shaft to motor, hold ratchet plunger lock with spring in place (see figure 16 in manual). Position ratchet as shown and then lower it into place." ~Ben |
Post# 239236 , Reply# 5   7/7/2013 at 06:13 (3,916 days old) by kirbykid63 (Wilmington Delaware)   |   | |
Replace the ratchet assembly this will solve that problem. |
Post# 239237 , Reply# 6   7/7/2013 at 06:39 (3,916 days old) by dysondestijl (east midlands, UK)   |   | |
My heritage has excactly the same problem |
