Thread Number: 21213
Hoover Turbopower Junior U1100: Wheels needed. |
Post# 237463 , Reply# 1   6/23/2013 at 15:25 (3,957 days old) by Turbo500 (West Yorkshire, UK)   |   | |
Post# 237528 , Reply# 4   6/24/2013 at 03:31 (3,957 days old) by slpj ()   |   | |
Here's a pic or two. |
Post# 237530 , Reply# 6   6/24/2013 at 03:34 (3,957 days old) by Turbo500 (West Yorkshire, UK)   |   | |
Post# 237534 , Reply# 8   6/24/2013 at 03:50 (3,957 days old) by slpj ()   |   | |
Here's one of the wheel spindle in the chassis. |
Post# 237666 , Reply# 19   6/25/2013 at 04:08 (3,956 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Sounds like they have just gone soft, they are quite stiff when new, certainly drags everything out of the carpet! |
Post# 238697 , Reply# 21   7/3/2013 at 05:20 (3,948 days old) by Turbo500 (West Yorkshire, UK)   |   | |
On doing a bit of digging around, part number 38528507 seems to be the drive belts for the US Soverign machines, which were identical to the Turbopower's.
Either way, here are the belts to fit your Turbopower. CLICK HERE TO GO TO Turbo500's LINK on eBay |
Post# 238700 , Reply# 22   7/3/2013 at 05:40 (3,948 days old) by slpj ()   |   | |
Hi there, Thanks very much for that. Do you happen to have the size dimensions for the correct belts? I don't want to discard perfectly good belts if I already have the correct ones. Thanks |
Post# 239442 , Reply# 23   7/9/2013 at 05:29 (3,942 days old) by slpj ()   |   | |
Hi, does anybody have the correct measurements for the drive belts, so I can see if mine are the right sizes? |
Post# 239458 , Reply# 24   7/9/2013 at 09:15 (3,941 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Mine measure 14.5cm on one side. held flat against a rule. So 2 x 14.5cm. Part number 03850121 |
Post# 239576 , Reply# 25   7/10/2013 at 05:51 (3,941 days old) by slpj ()   |   | |
Hi Beko1987, Thanks for that. Mine are longer and narrower, so I reckon I definitely have the wrong ones. I'll order new ones today. Many thanks. |
Post# 239690 , Reply# 26   7/10/2013 at 17:03 (3,940 days old) by vintagerepairer (England)   |   | |
Sounds like you have the Turbopower 2 belts. |
Post# 239814 , Reply# 27   7/11/2013 at 16:47 (3,939 days old) by SeamusUK (Dover Kent UK)   |   | |
Hi from Dover..... If you are anywhere near we have a later hardbag model going cheap- its a Total System with tools attached tho so the Chassis is different..... Cheers Seamus |
Post# 240032 , Reply# 28   7/14/2013 at 11:39 (3,936 days old) by SeamusUK (Dover Kent UK)   |   | |
We are scrapping a later Turbo Junior like the Blue one above- the motor is history and the Trunion is broken-however the wheels and chassis are good and the Agitator appears better than yours. Contact me or reply on here if you are interested... Seamus |
