Thread Number: 20935
Hello and I picked up a Super J |
Post# 234412 , Reply# 1   5/28/2013 at 21:05 (3,957 days old) by pr-21 (Middletown, OH)   |   | |
They make vinyl hoses that are much more flexible, dusting brushes, crevious tools and floor brushes are still made as well, including power nozzles. I would suggest looking on Ebay or Totalvac.com. Ebay you can find new or used, Totalvac.com will be new.
You can find Genuine or Generic parts to fit. The Genuine will obviously be more expensive. You could also buy directly from an Aerus store, but they would probably try to sell you a new one....If you bought from Aerus, they would have to probably order the parts for you. The hose you have has the electric running through it. To disconnect there are two tabs, one on each side that you push in and either pull out or put in the two slots until they click to connect to the canister. Sounds like you need a new hose bad, be sure your hose connector matches the new or used hose you buy. Don't buy a hose that fits the plastic machines, it will not fit. The older woven hoses always leak when they get older. There is a generic power nozzle and electric wand set that will fit your machine at a reasonable price. It is called Perfect, if you are looking on ebay or totalvac. Hope this gets you started. PR-21 |
