Thread Number: 20761
Pink Hoover Constellation.... |
Post# 232453   5/12/2013 at 17:23 (3,972 days old) by funvacfan (Canada)   |   | |
Post# 232463 , Reply# 1   5/12/2013 at 18:15 (3,972 days old) by vintagerepairer (England)   |   | |
I have never seen a floor tool quite like that pink one, well, not accounting for the Dyson floor tools of course. And to think I thought James Dyson had invented it. |
Post# 232464 , Reply# 2   5/12/2013 at 18:47 (3,972 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Hi Guy. Nice find.
That is one of the 3 debut models of the 'swivel-top' Constellation, which came out at the same time, manufactured from 1954 to 1957, when the hose connection was moved to the side on the Gold-painted 1958 Model 86. Yours is the TOL Model 85 in Heather Rose because it has the illusive wheeled swivel rug tool in matching colour. Double nice!
The two half-round tabs at the sides of the top are meant for cord wrapping and the 85 is the only Connie with them.
Many of the early Hamilton Constellations had colour-matched rubber bumper accents where their USA counterparts used only white.
Probably a Canadian Hamilton/Burlington build that will be revealed by the label tag on the bottom. If so, the model number may have a 3rd digit.
A replacement correct ultraflex hose probably has to come from a donor machine but yours looks split & taped only at one end. You can remove the hose glue at the end and shorten it a little, probably lose only 2" or less. Use a hairdryer to soften up the rubber collars and peel back to expose the wire wrap. Cut the hose at the point you want to save, pry off the damaged sections, clean up the ferrule and screw the saved hose on with rubber cement and a wire twist clamp.
I wash these type vinyl hoses in the kitchen sink or bathtub one section at a time, with a potato scrub brush & dish soap. Clean and sparkling as new...
Dave |
Post# 232467 , Reply# 3   5/12/2013 at 19:21 (3,972 days old) by kenkart ()   |   | |
the 82 came out in 55, the 84,56 and the 85 in 57. |
Post# 232475 , Reply# 4   5/12/2013 at 19:48 (3,972 days old) by funvacfan (Canada)   |   | |
Post# 232481 , Reply# 5   5/12/2013 at 20:24 (3,972 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
According to Tom Anderson in North Canton, all three came out within months of each other. The blue non-floating 82 was first, as the low-end model and the mulberry 84 floater as mid-tier and the Heather Rose 85 as TOL with all the additional features.
I've never seen a Canadian Connie with the wheeled floor nozzle. So if yours is a Hamilton machine that will answer that question. I found mine in Crevicetool's free pile at the Minneapolis Convention in filthy condition and scooped it up. Just dirty, it cleaned up like new without a scratch or smudge.
The side hose gold 86 continued (past the singular Garland Green electric hose 87) painted Porcelain Blue to match the Convertible upright.
Post# 232511 , Reply# 6   5/13/2013 at 06:45 (3,972 days old) by funvacfan (Canada)   |   | |
