Thread Number: 20688
Hoover 875 |
Post# 231611 , Reply# 1   5/7/2013 at 09:30 (4,006 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Another general picture |
Post# 231614 , Reply# 3   5/7/2013 at 09:36 (4,006 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Had to do this outside. |
Post# 231615 , Reply# 4   5/7/2013 at 09:38 (4,006 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Also, the handle and cord cover is looking pretty past it. Is there anything I can use to either reverse this or stop it getting any worse? |
Post# 231617 , Reply# 5   5/7/2013 at 09:41 (4,006 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Another main question, how do I get the fan blades off the motor? |
Post# 231618 , Reply# 6   5/7/2013 at 09:47 (4,006 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
And my favorite picture so far: |
Post# 231633 , Reply# 7   5/7/2013 at 11:36 (4,006 days old) by dysondestijl (east midlands, UK)   |   | |
Is this what our American friends call a 'coffee-can' hoover? |
Post# 231640 , Reply# 8   5/7/2013 at 12:11 (4,006 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 231682 , Reply# 9   5/7/2013 at 16:54 (4,005 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Thanks John. Lots of us got together earlier and had a brandy and cigar in his memory! |
Post# 232818 , Reply# 11   5/15/2013 at 18:19 (3,997 days old) by guido (ITALY)   |   | |
I have the same problem with some of my early HOOVERS : the handle cover and cable cover get sometime a sort of "rubber cancer" and start disintegrating. I think the plaque that covers the switch were simply "rubberized" with a sort of isolating paint, in order to improve isolation in this risky area, i suppose. Should it get worse, I would scrub it away and repaint the plaque with an ordinary paint that matches with the handle. Rubberized paints are anyway available in shops ( we call it CHLOROCAUCCIU' in Italy ) as it is often used for isolating old swimming pools or ponds, etc ). As far as the rubber handles, I was lucky enough to find a cheap NOS black handle for my model 160 ( which was falling into pieces like a biscuit and disintegrated completely when I removed it to fit the new one ) but still have to find a brown replacement for one of my HOOVER 262....by now I am keeping it "as is" cause I don't feel like fitting a different handle from other models and make a fake...curiously enough, other handles from the same period are perfectly kept and still soft, maybe they were better kept or simply maybe HOOVER Perivale might have used poor quality rubber during the WAR period, who knows ?!
By the way, I try to keep my rubber parts always polished with mineral oil ( the one used for sewing machines ) and sometimes treat them with few PNEUS OIL even if this sometimes give a "sticky" effect that attracts dust more then ever ! Hope this helps ! guido |
Post# 240898 , Reply# 13   7/19/2013 at 07:00 (3,933 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Spurred on by a reply on Hooverland (it is still going!), I had half an hour with the 875 yesterday, determined to find the source of the deadness! So, motor stripped down for the billionth time! (Needs to come apart again in the future for re-sealing but meh) From Hoover 875 I unscrewed the cable from the plug at the end, chopped off the ring terminals as it wouldn't fit in the spring and pulled them through. Removed the spring as well. From Hoover 875 And immediatly saw this! 'Found' some cable From Hoover 875 Choppy choppy From Hoover 875 crimpy crimpy From Hoover 875 and lots of heatshrink. Also covered the original other cable, to prevent this happening again. From Hoover 875 Fed the cable back through the spring, re-connected the plug, re-fitted the spring to the motor housing and pegged it into place From Hoover 875 Looks a bit naff, but it is safe, which I suppose is the main thing! From Hoover 875 You can't really see it though, so thats ok! From From Hoover 875 href="https://picasaweb.google.com/100613104539603912898/Hoover875?authuser=0&feat=embedwebsite">Hoover 875 From Hoover 875 Back together From Hoover 875 Happy with that, I connected the handle, put a 3a fuse into the plug and... Nothing. Some swear words were said, and I started to pack up. However, glancing over my box of crimps, I found some spade connectors which fitted the prongs of the plug, so wired the flex directly to the motor and... Sounding lovely after the motor rebuild too. Think I need new carbon brushes though, as you can see the sparking is excessive, and they make the tickety noise heard when on. Excited by this, I unplugged it, put the new belt back on and the belt guard, and saw and heard the beater bar for the first time (and I imagine the first time it's turned either in anger for decades) Had to push down on the front due to lack of weight from the handle. As you can see, it certainly beats. A hurricane was emitted from the rear too! So, the issue lies within the handle, so I checked and found enough cable to do a new run up the handle. I only had to remove the socket at the base... Tapped th wooden dowel out From Hoover 875 and that's where it went downhill again! The socket was in tight, possibly corroded. I tried several ways, and ended up snapping a massive chunk off. So, my next task is to smash the remains out, and remove the cable. Plan A to re-connect everything is using the spade terminals, and just to be careful when removing the handle. Plan B is to find another socket, but I imagine that's going to be pretty tough! Still, she runs! Will try to bodge it back together so I can run it around the front room and finally use it for the first time in months! |
Post# 380010 , Reply# 14   10/19/2017 at 17:59 (2,379 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
I finally got somewhere with it this week! Full story here: CLICK HERE TO GO TO beko1987's LINK |
Post# 380078 , Reply# 15   10/21/2017 at 17:17 (2,377 days old) by portable (Corvallis, OR)   |   | |
