Thread Number: 20552
Renaissance triac replacement. I'm being told I have to replace both the canister and handle boards |
Post# 230228 , Reply# 1   4/27/2013 at 09:16 (4,016 days old) by dysonman1 (the county)   |   | |
I've worked on many Renny's over the years. The board in the vacuum will fail if the old motor is pulling too many amps (which a bad commutator will do). Generally, the hose board is fine. There is a replacement (non genuine) hose for the Renny models that wholesales for less than a hundred dollars, but uses switches rather than a touch pad (like the last of the Renny series used). I'll bet just replacing the board in the canister is all you'll need to do. The board in the hose handle should be fine.
