Thread Number: 20204
Kirby Diamond Edition |
Post# 226390 , Reply# 1   4/3/2013 at 23:03 (4,039 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Have you checked the endcaps on your Kirby nozzle's brushroll? If the Kirby is burning through belts, the most likely cause is hair build-up in the endcaps & bearings. The other possibility is that you are using generic belts; in my experience, I have found that generic Kirby replacement belts don't work nearly as well as genuine Kirby belts, & they burn out quicker.
Hope this helps & you get the nozzle working properly on your Kirby! It would be a shame to waste such a good vacuum to hose cleaning only. Rob |
Post# 226758 , Reply# 4   4/5/2013 at 13:52 (4,038 days old) by marks_here (_._)   |   | |
I know the sentria I got wouldn't pick up anything from the carpets because the brushes were too stiff & it would bounce & skip across the floor & from time to time there was a burning smell & the belts would stretch out constantly. Now since I got a softer brush roll for it all those problems vanished. Mark
