Thread Number: 20146
Hoover U1012 Parts needed |
Post# 225709 , Reply# 1   3/30/2013 at 15:54 (4,037 days old) by andy-lux ()   |   | |
hi pal any pictures mate? |
Post# 225786 , Reply# 2   3/31/2013 at 07:09 (4,037 days old) by AlexHoovers94 (Manchester UK)   |   | |
Hi, I got your email, I just hadn't got the chance to reply, but I saw this thread (assuming it's you) so I will see if I can help you now.
I think parts such as the fill tube are obsolete but you can usually pick up a 1980's Hoover Junior of eBay really cheap, all the 80's Juniors have top fill tubes, I assume you know but what you are looking for is this... |
Post# 225787 , Reply# 3   3/31/2013 at 07:31 (4,037 days old) by AlexHoovers94 (Manchester UK)   |   | |
The handle release on mine doesn't work very well, if you try and push it around in the "locked" upright position it stays in that position for a few seconds and then drops down to operating position, all Juniors do this, because the 60's and 70's ones are getting on for 30-40 years and the metal on metal handle release has just worn from constantly being pressed and tugged on over the years. You may be able to get a "new one" from a vacuum shop as they usually sell the refurbished Juniors but I am not certain on that, plus it will be bright white and not the yellowy creamy colour of the U1012. If you need to get to the motor, there are four screws that need to be taken out. Fist take out the two screws that hold on the black bottom cover, then you will need a VERY long Phillips head screw driver (if you don't have an extra long one it just won't work, no innuendo!) and then unscrew those four screws, the motor will just lift out. When you have the motor out (from memory) you should just be able to unscrew three long flat head screws that have a bolt on the back, the motor casing should start to break into two when the screws are out, just remember that the screw and bolt that goes in at the rear of the motor is slightly longer than the other two, I think. The carbon brushes are held in by two little plates and there are two little flat head screws that hold them down in place, when those little screws are out the carbons will just spring right out. Hope this helps you, Alex. |
Post# 225788 , Reply# 4   3/31/2013 at 07:37 (4,037 days old) by AlexHoovers94 (Manchester UK)   |   | |
Post# 225790 , Reply# 5   3/31/2013 at 07:51 (4,037 days old) by dysondestijl (east midlands, UK)   |   | |
Hi there! I have a spare top fill tube if you want it, George |
Post# 226079 , Reply# 6   4/2/2013 at 08:19 (4,035 days old) by james_60 (Broadway)   |   | |
Hi George How much do you want for the top fill tube "same part as alexhoovers94" is showing James :-) |
Post# 226083 , Reply# 8   4/2/2013 at 08:30 (4,035 days old) by dysondestijl (east midlands, UK)   |   | |
I don't want anything for the top fill tube but I'm not too sure about how shipping is gonna work, I'm not sure how much it will cost to ship?? I'll look into it at some point:) |
Post# 226085 , Reply# 9   4/2/2013 at 08:54 (4,035 days old) by james_60 (Broadway)   |   | |
Hi George Can I have your post code so I can see how far away you are from me with my satnav James p.s iam near Evesham Worcestershire |
Post# 226098 , Reply# 10   4/2/2013 at 11:46 (4,035 days old) by dysondestijl (east midlands, UK)   |   | |
I am from Derbyshire, East Midlands |
Post# 226099 , Reply# 11   4/2/2013 at 11:58 (4,035 days old) by dysondestijl (east midlands, UK)   |   | |
I emailed you |
Post# 226112 , Reply# 12   4/2/2013 at 14:49 (4,034 days old) by AlexHoovers94 (Manchester UK)   |   | |
Post# 226320 , Reply# 13   4/3/2013 at 17:03 (4,033 days old) by AlexHoovers94 (Manchester UK)   |   | |
Not sure if you are bidding but there are these on eBay if you need a new one, you could stock up :P.
CLICK HERE TO GO TO AlexHoovers94's LINK on eBay |
Post# 226794 , Reply# 14   4/5/2013 at 17:57 (4,031 days old) by james_60 (Broadway)   |   | |
Hi What else can it be if it isn't a U1012 I would like that topfill please Just wrap it in brown paper and send it via myhermes James |
Post# 226795 , Reply# 15   4/5/2013 at 17:58 (4,031 days old) by james_60 (Broadway)   |   | |
Will anyone swap the blue front and blue bag for the correct coloured items (honey) James |
Post# 227514 , Reply# 16   4/9/2013 at 05:42 (4,028 days old) by james_60 (Broadway)   |   | |
Anyone ? and p.s please can I have the top filler James |
Post# 227532 , Reply# 17   4/9/2013 at 10:55 (4,028 days old) by dysondestijl (east midlands, UK)   |   | |
yes, but what is 'myhermes'??? |
Post# 227710 , Reply# 18   4/10/2013 at 13:27 (4,026 days old) by Alexhoovers94 (Manchester UK)   |   | |
Post# 383606 , Reply# 19   1/5/2018 at 10:07 (2,296 days old) by James_60 (Broadway)   |   | |
dysondestijl are you still around |
Post# 383810 , Reply# 20   1/8/2018 at 01:38 (2,293 days old) by Gj3476 (Prosper,TX)   |   | |
Post# 384230 , Reply# 21   1/14/2018 at 12:59 (2,286 days old) by James_60 (Broadway)   |   | |
yes it was ebay back in 2013. are they rare ? James |
