Thread Number: 20074
Air Way Vacuum Motors
Post# 224941   3/24/2013 at 04:10 (4,043 days old) by thermokid (Casper, Wyoming)
I need to find out where I can purchase a motor that will fit in my Airway vacuum... The vacuum is White with a Black bottom with a power nozzle. I was vacuumming with it and it started making a strange noise and then started to make an Burnt Electrical smell and the motor slowed down. So I know it needs a new motor. A two stage one I think.... Any suggestion where to find one? Dan
Post# 224962 , Reply# 1   3/24/2013 at 10:29 (4,043 days old) by whirlsonicmore (South US)
A picture of the motor would help, or at least the numbers from the tag on the motor.
Post# 225070 , Reply# 2   3/25/2013 at 11:32 (4,042 days old) by Good-Vac ()
This post has been removed by the webmaster.
Post# 225092 , Reply# 3   3/25/2013 at 14:07 (4,042 days old) by kenkart ()
The motor is...
Just a standard lamb motor, used in Compacts FilterQueens ETC, Two fan double ball bearing, you can install any Lamb from the 50s on thru present day, it will fit.
