Thread Number: 20004
Best Basic Vacuum with roller brush/upright or cannister |
Post# 224177 , Reply# 1   3/18/2013 at 17:25 (4,055 days old) by stricklybojack (Southern California)   |   | |
Buy it at the Ebay link provided for $39 shipped which is less 1/3 of what it sold for last year. The unit sold is basically new without the original packaging.
It is a 2 motor light weight machine with a serious brush roll & is bagged. It has been written about on this site before & praised highly. This price is outstanding. I bought one and am simply amazed at the value. CLICK HERE TO GO TO stricklybojack's LINK on eBay |
Post# 224178 , Reply# 2   3/18/2013 at 17:38 (4,055 days old) by bagintheback (Flagstaff, Arizona)   |   | |
What size wands does the shop vac use? If the TurboCat will fit, then this is the best solution. The type of dirt that finds itself in outdoor carpeting clogs vacuum bags quickly, and new cyclonic vacuums are expensive.
CLICK HERE TO GO TO bagintheback's LINK |
Post# 224181 , Reply# 3   3/18/2013 at 18:13 (4,055 days old) by eurekaprince (Montreal, Canada)   |   | |
You should be aware that most manufacturers advise not to use their vacuum cleaners outdoors or on wet surfaces as this can create a shock hazard. You can only use a wet-dry vac that is designed to be used outdoors. That being said, indeed an air-driven turbo nozzle may be the best solution for your situation. You can probably get an adapter to make any turbo nozzle fit the wand of your Shop Vac.
Good luck! :-) |
