Thread Number: 19861
Differences Between Kirby Sentria and Sentria II? |
[Down to Last] | ![]() |
Post# 222068   3/5/2013 at 23:53 (1,875 days old) by kirbytradition7 (Denver (Aurora), CO, USA)   |   | |
Are there any significant differences between the two Kirby Sentria models (Sentria and Sentria II)?
There are some cosmetic changes (in terms of colour of trim and bag). The hand grip at the bottom of the Sentria II handle is blue, vs. the orange hand grip on the Sentria, and the bag on the Sentria II has a retro brown/blue design vs. the grey bag on the Sentria with abstract squares on it. The Mini-Emtor on the Sentria II appears smaller than that on the original Sentria. Is that all the difference there is? |
Post# 222084 , Reply# 1   3/6/2013 at 03:55 (1,875 days old) by tolivac ![]() |
Would like to know what side-to-side differences there is too,otherwise waiting for the "2014" Kirby.So far no Kirby salesfolks knocking on my door. |
Post# 222088 , Reply# 2   3/6/2013 at 04:40 (1,875 days old) by pr-21 ![]() |
Post# 222090 , Reply# 3   3/6/2013 at 04:43 (1,875 days old) by pr-21 ![]() |
Post# 222091 , Reply# 4   3/6/2013 at 04:45 (1,875 days old) by pr-21 ![]() |
Post# 222121 , Reply# 5   3/6/2013 at 13:13 (1,875 days old) by KirbyUltimateG (Troy Ohio 45373 USA)   |   | |
Paging A007KirbyMan! :) |
Post# 222151 , Reply# 9   3/6/2013 at 15:15 (1,875 days old) by a007kirbyman ![]() |
Hello Rob (& all).
Bud (pr-21) pretty much 'nailed it' with the 'changes' that are on the Sentria II Kirby, as did Francis (kirbytradition7) with the 'cosmetic ones.' However, that said, these changes (with the exception of the colors & bag pattern) were all done as "rolling changes" on the prior model Sentria. The 'changes' started back around 2007. Some of these other changes, not mentioned above include the Zipp Brush, bag zipper, polymer base pan, 4-position handle pivot assembly, surface nozzle wheels, etc. They ARE LIGHTER than previous "G model" Kirbys, (& even MORE DURABLE with the polymer material.) [[ I was initially concerned, when they (The Kirby Co./SF) started using 'other' materials than aluminum, like they've used for approximately 85 years! I've found that quality & durability is NOT an issue. ]] The airflow (hence cleaning) is more powerful with the re-designed Emtor. It is a 'smoother' path for the air (& debris) to reach the bags. If anyone desires add'l info on 'changes', I encourage you to refer to one of my prior posts in this thread (if the link at the bottom here does not work): www.vacuumland.org/cgi-bin/TD/TD-... I hope this info. helps clarify a few things. Cheers & hagd all, Bill Hopefully!!! ...that work(s/ed), for your entertainment. If not, I've included the actual link. ~~lol~~ CLICK HERE TO GO TO a007kirbyman's LINK |
Post# 242778 , Reply# 11   7/29/2013 at 13:01 (1,730 days old) by farmvet01 ()   |   | |
...for the older machines (Classics, Dual Sanitronics and 500 series)? Maybe I should post this question on the Vintage forum. |
Post# 249128 , Reply# 12   9/4/2013 at 21:09 (1,693 days old) by chicagomike ![]() |
One big change I see from Sentria 1 to 2 is --- the transmission on the S2 - you cannot push the vacuum without the power turned on if in the drive position with the S2 --- which I think was a great change from S1 to S2 as the S1 would allow you to push the vacuum around without power it on if left in the drive position..
Post# 249129 , Reply# 13   9/4/2013 at 21:12 (1,693 days old) by chicagomike ![]() |
