Thread Number: 19802
Vintage Electrolux metal nozzle question |
Post# 221170 , Reply# 1   2/28/2013 at 17:26 (4,068 days old) by gal220joy ()   |   | |
I guess you could say my question is - is it normal for a nozzle like this one to come to a "stop" in one direction that keeps it from proceeding? |
Post# 221182 , Reply# 2   2/28/2013 at 18:24 (4,068 days old) by caligula (Wallingford, Connecticut)   |   | |
No! There's a problem here, but most likely it's a quick fix.
The coupling that holds it to the wand or hose handle should turn completely, and there should be no squeek, or click! Take a screwdriver, and remove the bottom brush assembly, there's a rubber gasget, I think that's the problem. It's most likely worn out, and pressing on the coupling. There might also be dirt in there, take it apart and have a look. You should also give it a squirt of WD-40 before you reassemble it. This tool was first introduced with the model XXX in 1937 and was in production till the introduction of the model E which was about 1955, so no doubt it's gotten a lot of use. Take it apart, see what you find, and let me know. Alex Taber. |
Post# 221195 , Reply# 3   2/28/2013 at 19:18 (4,068 days old) by gal220joy ()   |   | |
Yea, thanks, you pointed me in the right direction. The spring inside was hanging up in a hole, and a little fine tuning got it working. Should do alright. Thanks again. |
Post# 221333 , Reply# 4   3/1/2013 at 17:30 (4,067 days old) by RobAnderson ()   |   | |
Does anyone know of a source for new rubber bumpers for this nozzle. Thanks |
Post# 221339 , Reply# 5   3/1/2013 at 18:05 (4,067 days old) by caligula (Wallingford, Connecticut)   |   | |
Unfortunately no, I wish there was as I could use several of them.
All of my early model Electrolux's from the X11 to the LX1, be that bare floor brush, rug tool or dusting brush need the rubber trim replaced, and in the correct colors. If you find somebody who can make them for us, let me and the rest of us know. |
