Thread Number: 19703
Rookie Kirby mistake! |
Post# 219659   2/18/2013 at 14:55 (4,083 days old) by stricklybojack (Southern California)   |   | |
I stripped the nozzle lock lever screw anchor threads (not the screw threads) when i removed the lever, doh!
For those who don't know when you want to acess the fan area on a Generation3 thru Sentria do not remove the nozzle lock lever screw as it has been flattened at the factory to remain in place permanetly. Yes it turns but leave it be! The link is to a replacement case plate which is where i found the above info. Straightned out my, 'factory defect' theory. So although the vac works fine regardless of my screw up (heh heh), it is clear i need to fix this. Is a replacement case face plate the best way to go or is there a way to restore the tapped threads i have now 'pert near ruined? CLICK HERE TO GO TO stricklybojack's LINK on eBay |
Post# 219695 , Reply# 1   2/18/2013 at 18:40 (4,083 days old) by goadie12 ()   |   | |
It all depends on how much you want to spend but $20 does not seem bad especially if you are not able to re-drill the holes easily. Just my two cents thanks. Zach |
Post# 222882 , Reply# 4   3/10/2013 at 10:38 (4,064 days old) by 2011hoover700 (owosso michigan)   |   | |
Post# 335649 , Reply# 5   10/13/2015 at 17:58 (3,116 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 335657 , Reply# 6   10/13/2015 at 18:54 (3,116 days old) by CharlesKirby66 (Manteca, CA)   |   | |
