Thread Number: 19415
How to ? Tri Star |
Post# 215146 , Reply# 1   1/21/2013 at 16:02 (4,111 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Brad, there are only three bolts holding the halves together, no more and no less - no clips, tabs or adhesives. The halves join together dry in channels of the rubber bumper surround.
One bolt is at center front below the bag door latch and the other two reside inside the wheel wells of the rear wheels. You have to knock out the drift pin that serves as an axle to get at those bolts. Then simply pull the halves apart. Compact and Tristar shells are cast in magnesium. It is very lightweight but also brittle. All 3 bolts must be removed before attempting to separate the halves or you run the risk of cracking the shell or bolt mount posts. For reassembly. it is best to knock the axle pins outward from the belly and observe which end has the knurled edge - usually the inner end. Which should be the last section of the pin to be knocked home. The knurl locks the pin in the holes so it will not work loose in future. Pin are replaced in reverse fashion, pressing and hammering them flush with a hammer and cloth bushing pad to avoid marring the paint. The picture shows the bolt locations as yellow dots. Dave This post was last edited 01/21/2013 at 17:03 |
Post# 215166 , Reply# 2   1/21/2013 at 17:29 (4,111 days old) by beerad (Beautiful Vancouver BC)   |   | |
Thanks for the info. I. Still am having a challenge pulling the two halves of the vacuum apart???? |
Post# 215170 , Reply# 3   1/21/2013 at 17:37 (4,111 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Are the 3 bolts out yet?
Then I'd say that the rubber bumper grooves have been made wet at some point turning the schmutz into some sort of glue. Carefully insert a thin blade screw driver top under the rubber bump strip entering the seam, working your way gently around the perimeter. The halves will at some point pop apart, trust me. Dave |
Post# 215507 , Reply# 4   1/23/2013 at 19:57 (4,109 days old) by beerad (Beautiful Vancouver BC)   |   | |
I got the effing Tri star apart. It took me about 2 hours of fiddling with the rubber seal. This was the most difficult one yet. Thanks for your help Dave. Brad |
Post# 215528 , Reply# 5   1/23/2013 at 21:33 (4,108 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Yippee. Wash the rubber bumper in hot water & dish soap to thoroughly clean out the schmutz and let it dry thoroughly before reassembly. Use a toothbrush to get deep into the groove channels. Mr Clean Magic Eraser will rub off any stubborn scuffs and baseboard paint transfer. Never reassemble a vacuum cleaner or any other metal electric device until the washed parts are bone dry. Any trace of moisture will only promote rust and corrosion. (as does moisture displacing WD-40 temporary lube - I do not allow it on my workbench)
But you know this...:-) Dave |
Post# 215531 , Reply# 6   1/23/2013 at 22:22 (4,108 days old) by kirbykid (Horseheads,New York 14845)   |   | |
finally someone else that thinks wd-40 will cause rust. everyone else that i talk to thinks im crazy because they think oil cant cause rust |
Post# 215532 , Reply# 7   1/23/2013 at 22:30 (4,108 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 215538 , Reply# 8   1/23/2013 at 22:52 (4,108 days old) by kirbykid (Horseheads,New York 14845)   |   | |
i thought it was just regular 3 in 1 oil with water added so it can be sprayed. |
Post# 215730 , Reply# 10   1/25/2013 at 02:00 (4,107 days old) by beerad (Beautiful Vancouver BC)   |   | |
shiny |
Post# 215731 , Reply# 11   1/25/2013 at 02:01 (4,107 days old) by beerad (Beautiful Vancouver BC)   |   | |
view |
Post# 215732 , Reply# 12   1/25/2013 at 02:02 (4,107 days old) by beerad (Beautiful Vancouver BC)   |   | |
it takes beautiful pictures, BUT, why do they come up side ways when I post them??? Does anyone know? |
Post# 215738 , Reply# 13   1/25/2013 at 04:10 (4,107 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
* because it IS an effing iphone. * :-)
Other iphone users will have to chime in here. But seriously Brad, I do not and would not have an iphone; my cellphone is a Blackberry and I use extensively my Blackberry Playbook 64 GB tablet. Both can shoot pictures and HD video. Video shot with either downloads in correct horizontal aspect nop matter what angle I hold the cameras at. When I download photos I auto-rotate those shot at 90 degrees in picture editing software. But I must say the resolution of tady's cell camera lenses have come a looooong way. Your pictures are beautifully clear and the shine you put on the Compact almost requires sunglasses. Wonderful resto, Brad. Thank you for providing the link, too. Gonna get me some... Dave |
Post# 215847 , Reply# 14   1/25/2013 at 18:32 (4,107 days old) by beerad (Beautiful Vancouver BC)   |   | |
Post# 219177 , Reply# 15   2/14/2013 at 21:56 (4,086 days old) by floor-a-matic (somewhere)   |   | |
Nice TriStar. |
Post# 220919 , Reply# 16   2/26/2013 at 17:51 (4,075 days old) by KirbyUltimateG (Troy Ohio 45373 USA)   |   | |
Very nice TriStar Brad! :) Are you going to install the Vibra Groomer III Disturbulator in the PN? |
Post# 221000 , Reply# 18   2/27/2013 at 13:13 (4,074 days old) by jfalberti (Visalia, CA)   |   | |
Hi Brad,
I have the same problem. Here is a link that explains the problem and how to work around it. Hope it helps. Basically, if I want to post a picture to VCCC taken on my iPhone, then I have to download the pictures to my computer, then post them to the site and all is good. CLICK HERE TO GO TO jfalberti's LINK |
