Thread Number: 19157
electrolux hose |
Post# 211468   12/28/2012 at 13:08 (4,134 days old) by FantomFan (Rochester, New York)   |   | |
Post# 211487 , Reply# 1   12/28/2012 at 15:18 (4,134 days old) by BrianKirbyClass (Eudora Kansas)   |   | |
Well, maybe. You could try it, but your best bet is to get a new hose.
IF you are not fussy about Genuine parts,,you can get a generic replacment hose for your DJ for under 50 dollars on E-Bay. Or, ask at your local vac shop for a used saran hose. Anything would be better than what you have now! Those original woven hoses were notorious for wearing out and leaking suction. |
Post# 211490 , Reply# 2   12/28/2012 at 16:04 (4,134 days old) by FantomFan (Rochester, New York)   |   | |
Post# 211491 , Reply# 3   12/28/2012 at 16:07 (4,134 days old) by powermate1970 ()   |   | |
I've tried everything from different kinda of tape to liquid adheasive/sealer, and I haven't found anything that I can say really works. |
Post# 211513 , Reply# 4   12/28/2012 at 19:15 (4,134 days old) by FantomFan (Rochester, New York)   |   | |
Post# 211568 , Reply# 6   12/29/2012 at 01:00 (4,134 days old) by BrianKirbyClass (Eudora Kansas)   |   | |
Post# 211569 , Reply# 7   12/29/2012 at 01:02 (4,134 days old) by BriGuy (Wichita, Kansas)   |   | |
As Richard said, you can use Plasti Dip to coat the inside of the hose to make it airtight. There have been previous threads where the latexing process is described step-by-step. I have have used liquid latex on one of my woven hoses with good sucess. Dave Kerr (AeolianDave)has posted his latexing procedure here & that's the one I have used. I found the liquid latex at Hobby Lobby in the model train section.
By the way Richard, hello to a fellow Kansan from down the road in Salina. |
Post# 211589 , Reply# 9   12/29/2012 at 06:52 (4,133 days old) by Real1 ()   |   | |
you can use 'crystal clear' heat shrink tubing to seal the entire hose forever. Probably no stiffer than the new LUX hoses.....
Kevin |
Post# 213084 , Reply# 13   1/7/2013 at 23:36 (4,124 days old) by floor-a-matic (somewhere)   |   | |
How can I remove the curved metal wand or pistol grip of a non-electric hose without breaking the pistol grip handle? |
Post# 213189 , Reply# 14   1/8/2013 at 20:00 (4,123 days old) by lux14 (Leawood Kansas)   |   | |
You will see a small ring on the end of the metal wand or pistil grip where the hose swivels. You will need to very very carefully get ahold of the end of the ring and pry it out very carefully. |
