Thread Number: 18875
Kenmore troubles |
Post# 207792 , Reply# 1   11/26/2012 at 00:03 (4,162 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Bad bearings. |
Post# 207811 , Reply# 2   11/26/2012 at 09:47 (4,162 days old) by rugsucker (Elizabethton TN)   |   | |
This can be bad motor as above.But many KM noises can be related to clogging.Run with dirt cup removed or bag door open and see if sound returns to normal.If so there could still be a clog. If still sounds bad(with brush off) would be bearing/fan/motor problem. |
Post# 207957 , Reply# 3   11/27/2012 at 00:53 (4,161 days old) by chan55 (Green Bay, WI)   |   | |
Thanks for the tips. I wonder if it pays to get it fixed. |
Post# 207972 , Reply# 4   11/27/2012 at 09:52 (4,161 days old) by Durango159 (State College, PA)   |   | |
Post# 208022 , Reply# 5   11/27/2012 at 15:31 (4,160 days old) by director12 ()   |   | |
My old purple Kenmore bagless from 2009 had that after new filters. |
Post# 208084 , Reply# 7   11/28/2012 at 18:11 (4,159 days old) by fan-of-fans (USA)   |   | |
I would say it could be a clog, especially since the performance indicator is on. It sounds like there could be a piece of paper or plastic stuck that is vibrating and making the flapping noise. If you can, try removing the hose from the machine at both ends and turn it on to see if it still does it. Also try what rugsucker said about turning the brushroll off to see if it isn't that.
Post# 208086 , Reply# 8   11/28/2012 at 18:54 (4,159 days old) by piano_god (British Columbia, Canada)   |   | |
Post# 208108 , Reply# 10   11/28/2012 at 22:37 (4,159 days old) by chan55 (Green Bay, WI)   |   | |
Mine just started this recently, and it is whenever it is on high speed. The noise seems to be coming from near the motor.If I turn it down it stops, but then you have no suction.......... |
Post# 208109 , Reply# 11   11/28/2012 at 22:38 (4,159 days old) by chan55 (Green Bay, WI)   |   | |
Post# 208316 , Reply# 14   12/1/2012 at 18:23 (4,156 days old) by gmerkt (Edmonds WA)   |   | |
Never mind checking the pre-motor filter as the cause of the bleeder opening on the bagged version. Good idea to check it anyway, though. |
Post# 208322 , Reply# 15   12/1/2012 at 20:13 (4,156 days old) by electroluxxxx (……)   |   | |
if the hose is clogged and it is a stretch hose try flexing the hose vigorously with the vacuum on. I was taught that by a vac shop years ago and it seems to work well. a broom handle also works if the opening is wide enough |
