Thread Number: 18637
old royal hand vac issue |
Post# 204924   10/27/2012 at 00:56 (4,192 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
I recently acquired an old red and black handvac that predates the 501 series. The issue is that when the motor is not under load it spins fast and strong. When I attach the belt it slows down drastically. The bearings are oiled and quiet, the belt is correct, brushroll is fine. My guess is the armature is going bad. Any ideas my friends?
Post# 204926 , Reply# 1   10/27/2012 at 03:48 (4,192 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Whenever the belt is successfully attached between the motor shaft and the brush roll, yes, the motor speed will be reduced slightly, but what I think you're saying is that it does so moreso than you think it should.
I say if that's the case, then it may very well be the armature. I think you may have a model 157. ~Ben |
Post# 205022 , Reply# 2   10/27/2012 at 22:23 (4,191 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
