Thread Number: 18442
Royal Motor Upgrades - How High Do You Want to Get? |
Post# 202759   10/4/2012 at 21:06 (4,192 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
To paraphrase Donkey Kong's opening gameplay phrase: "How high do you want to get?"
Anyway, my question is this: for those of you who own a Royal with a 3 amp or older motor assembly (most models manufactured before August 1980), how many of you have tried to take on upgrading it to a higher-amperage motor? According to the latest version of the Royal service manual, the following upgrades can be used: To upgrade to a 6.0 amp motor, use these following parts: #1680001000 Armature (procure from donor 1985 to 1995 Royal) #1618002000 Field #2088075000 Motor Plate Assembly (procure from donor 1985-95 Royal) #2080126000 Rear Bearing (procure from donor 1985-95 Royal) #1608005000 Fan #1380261000 Shaft To upgrade to a 7.0 amp motor, use these following parts: #1780001000 Armature #1618002000 Field #2088075000 Motor Plate Assembly (procure from donor 1985-95 Royal) #2080126000 Rear Bearing (procure from donor pre-1995 Royal) #1608005000 Fan #1380261000 Shaft Parts Needed for Motor Plate Assembly #1884003000 Motor Plate (procure from donor pre-1995 Royal) #1880026000 Ball Bearing (procure from donor pre-1995 Royal) #1880046000 Tolerance Ring ~Ben |
