Thread Number: 18398
Is it possible to use any shampoo solution on a Kirby G series? |
Post# 202182 , Reply# 1   9/28/2012 at 18:33 (4,199 days old) by kirbykid (Horseheads,New York 14845)   |   | |
i have been using miscelaniouse carpet shampoos for the kirby g4 but i got them from starks and they said it was ok |
Post# 202231 , Reply# 3   9/29/2012 at 02:08 (4,198 days old) by troopersam (Perris)   |   | |
I found some other brands. CLICK HERE TO GO TO troopersam's LINK |
Post# 202232 , Reply# 4   9/29/2012 at 02:17 (4,198 days old) by troopersam (Perris)   |   | |
And another. You can probably find more with a google search. The important thing is PLEASE, do not use shampoo meant for an extraction system. CLICK HERE TO GO TO troopersam's LINK |
Post# 202258 , Reply# 5   9/29/2012 at 10:50 (4,198 days old) by trebor ()   |   | |
that extraction type shampoos should not be used in the Kirby shampooer, Kirby now makes a solution for extraction type machines. |
Post# 202262 , Reply# 6   9/29/2012 at 11:47 (4,198 days old) by kirbykid (Horseheads,New York 14845)   |   | |
what will hapen to your kirby if you use foamy shampoo? thats what ive been using. |
Post# 202263 , Reply# 7   9/29/2012 at 11:48 (4,198 days old) by kirbykid (Horseheads,New York 14845)   |   | |
and it wasnt dry foam... |
Post# 202266 , Reply# 8   9/29/2012 at 13:07 (4,198 days old) by eurekastar (Amarillo, Texas)   |   | |
If you don't use dry foaming shampoo in your Kirby, you'll end up leaving a lot of soap residue in the carpet. All that soap residue will will just attract more dirt and grim. On the other hand, dry foam shampoo is scrubbed into the carpet but leaves the carpet fairly dry. When it is completely dry, the carpet is then vacuumed to remove the soap residue and any dirt that it gets out. That won't happen if you use extraction shampoo. |
Post# 202310 , Reply# 9   9/29/2012 at 21:27 (4,198 days old) by SanitaireBoy97 ()   |   | |
So if I were to use what's left of my Bissell shampoo on a Kirby, its just going to leave a soapy residue on my carpets? |
Post# 202317 , Reply# 10   9/29/2012 at 22:51 (4,198 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Well atleast it didn't ruin my kirby bearings. But I vacuum the carpet regularlyand it looks fine. I gues Iwill be going to starks to get more shampoo |
Post# 202324 , Reply# 11   9/30/2012 at 00:23 (4,198 days old) by Kirbysthebest (Midwest)   |   | |
Set the bottle down and step away from the Kirby. Kirby uses a dry foam, using something else will leave residue, could over saturate the carpet, and could damage the Kirby. |
Post# 202328 , Reply# 12   9/30/2012 at 00:28 (4,198 days old) by kirbykid (Horseheads,New York 14845)   |   | |
it could damage my kirby?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!? if there is damage to my kirby, does that mean that starks scamed me into breaking my kirby so they can make more money fixing it????? i have been using the wet foamy stuff for 4 to 5 years now |
Post# 202498 , Reply# 13   10/1/2012 at 17:17 (4,196 days old) by SeamusUK (Dover Kent UK)   |   | |
Any DRY FOAM shampoo will work but def not one intended for extraction!!! This works and is cheap!! Seamus CLICK HERE TO GO TO SeamusUK's LINK |
Post# 202522 , Reply# 15   10/1/2012 at 20:59 (4,196 days old) by kirbykid (Horseheads,New York 14845)   |   | |
ya |
