Thread Number: 1825
OK Just Because I'm Coming to the VCCC Convention |
Post# 19602   8/25/2007 at 19:27 (6,060 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 19603 , Reply# 1   8/25/2007 at 19:35 (6,060 days old) by unimatic1140 (Minneapolis)   |   | |
Here I am trying it out, it works perfectly and so does the polisher attachment. It did take me a minute to figure out how to make the polisher work the hose needs to be placed into the exhaust. If this vacuum and attachments are something that someone here really wants and is coming to the convention let me know and I can bring it down to Omaha for you.
Post# 19605 , Reply# 2   8/25/2007 at 22:03 (6,060 days old) by crevicetool (GA )   |   | |
to anything in the photo of you and your Compact. Please re-do it and hand it in first thing in the morning. Until then you get and incomplete and I'm sending a note home to your folks. |
Post# 19607 , Reply# 3   8/25/2007 at 22:59 (6,060 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Robert, that is a fine looking Compact C-2 manufactured from 1949 thru 1952, if in fact it has two support bumps protruding from the body belly front, instead of the later single caster. Sure does look purty & all. The body decal graphic looks excellent. I have the later model A-2 Interstate Polish-Aire in turquoise green. Uses a heavy flywheel turbine that drives one O-ringed polisher head with a knurled post. The second O-ringed head is spring loaded against the first to counter rotate. This thing has torque to spare! What's the model # of your Polish-aire, if the decal is still intact on the bottom casting. A-1 maybe? CLICK HERE TO GO TO aeoliandave's LINK |
Post# 19623 , Reply# 5   8/26/2007 at 08:20 (6,059 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 19624 , Reply# 6   8/26/2007 at 08:23 (6,059 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 19652 , Reply# 8   8/26/2007 at 10:14 (6,059 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
Post# 19653 , Reply# 9   8/26/2007 at 10:16 (6,059 days old) by aeoliandave (Stratford Ontario Canada)   |   | |
