I've finally started using it, and it's blowing me away! What a great utility vacuum!
So quiet compared to a Shopvac or to my beloved Sanitaire Mity-Mite. Interesting that the specs are so lack-luster, and yet it picks up like crazy! What gives?
If it had a powered hose, it might very well be in my house as my daily driver. That's over my Tri-Star CXL!
Check out the specs:
Motor: 1.25 hp (8 amp)
Motor Type: Two-stage, non-bypass
Electrical: 115V, 60Hz, 1000W
Sound Level: 68 dB(A) @ 6'6"
Air Flow: 66 cfm
Sealed Water Lift: 91" wc
Why does it clean so well with such airflow numbers? I'm perplexed. Fantastic straight suction performance.
