Thread Number: 17577
Electrolux Prolux Plus take apart help |
Post# 190088   7/15/2012 at 20:34 (4,295 days old) by macmansam (Minnesota )   |   | |
I can't for the life of me get it to open. Does anyone have like a "how to" or an owners manual? My serial number is P09236E if that helps. I want to take it apart and clean out the motor and inside. There are 2 screws underneath where the bag goes, but they are in a really awkward spot. Thanks in advance!
Post# 190112 , Reply# 1   7/15/2012 at 23:13 (4,295 days old) by dustin (Jackson, MI)   |   | |
Post# 190162 , Reply# 2   7/16/2012 at 09:47 (4,294 days old) by rugsucker (Elizabethton TN)   |   | |
As with most jobs the right tool helps.There is a screwdriver with extra long shaft that allows the handle to extend beyond bag compartment.Perhaps you can buy(check auto or tool stores)or borrow(have a neighborhood mechanic you deal with?).Handle comes off first. |
Post# 372484 , Reply# 4   5/20/2017 at 22:37 (2,525 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 374618 , Reply# 6   6/28/2017 at 22:01 (2,486 days old) by compactc9guy (Bathurst NB)   |   | |
first and for most those are tricky i rebuilt one like it few years back mine was discovery 2 tho same thing different color .
the screws on the bottom of the power foot 4 then take out the screws on the back of the machine that hold the two half of the unit then the handle should come off then pry it off gently the cord the upper half then the bottom half then the suction tube inside motor comes out of the bottom msg me if you need help i had a lux upright Electrolux Discovery 2 and i KEPT ALL MY RESTORATION PICTURES to replace the duct you need to open her up msg me i have a discovery 2 |
Post# 374925 , Reply# 7   7/5/2017 at 14:26 (2,479 days old) by human (Pines of Carolina)   |   | |
One interesting difference (improvement, really) I noticed between the ProLux pictured and my Discovery II is the funnel-shaped collector that goes between the brush roll and the duct tube is held down to the chassis with two screws, which keeps the collector firmly in place when the cover and chassis are separated. My Discovery II has a couple of locator pins on the chassis that allow the collector to be properly positioned for assembly but don't hold it in place. When the cover is removed, the collector tends to stay with the cover instead of on the chassis. Those two little screws make things a lot easier to take apart and put back together.
