Thread Number: 17559
Kirby Heritage |
Post# 189869 , Reply# 1   7/14/2012 at 07:23 (4,275 days old) by eurekastar (Amarillo, Texas)   |   | |
It's been a long while since I worked on one of these...But as I recall, the headlight cover is held on with a roll pin. The pin provides tension which allows the cover to stay up. It may be worn. Therefore, you'll need to knock it out with a long punch pin that's the same (or slightly smaller) diameter as the pin and then install a new one. I don't think there's any way of doing it without removing the fan case first. I always used to wrap it in cloth and clamp the fan case down in a vise in order to stabilize it. Care must also be taken with the lugs on the fan case, lest you break one while knocking out the pin. |
Post# 189891 , Reply# 3   7/14/2012 at 14:23 (4,274 days old) by eurekastar (Amarillo, Texas)   |   | |
