Thread Number: 17550
Help! |
Post# 189685   7/12/2012 at 18:41 (4,299 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 189714 , Reply# 1   7/12/2012 at 23:39 (4,299 days old) by thevacuumlover1 ()   |   | |
uhh.. it's hard to explain with out a somatic or a manual which i do not have.. i reccomend a pipe snake.. try shoving that trough the intake and other inlets |
Post# 189754 , Reply# 2   7/13/2012 at 09:32 (4,298 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 189779 , Reply# 3   7/13/2012 at 12:47 (4,298 days old) by sanitairered (Michigan)   |   | |
Post# 189847 , Reply# 4   7/13/2012 at 23:14 (4,298 days old) by Durango159 (State College, PA)   |   | |
Post# 190114 , Reply# 5   7/15/2012 at 23:31 (4,296 days old) by FantomVacuumFan (St.Petersburg, Florida)   |   | |
when looking for a clog, there are a few areas you can check. First of all, as a few people suggested, you can remove the screws under the headlights, and look in the suction inlet for a clog, and fish it out if you see one. Second, as also suggested, open the clean-out port on the back side above the handle realease/below the hose, and again check for a clog. Make sure to partially recline the vacuum or you may not see a clog in the base. FInally, there is a small clear window on the backside of the Cyclone XT, where the dirt enters the collection bin area. Check that for a clog, and if there is one, turn the machine around and pull it out through the opening where the dirt enters the bin.
I have a PDF of the Cyclone XT manual, I will email it to you! |
