Thread Number: 16838
Rainbow D2 |
Post# 179841 , Reply# 1   5/3/2012 at 22:37 (4,369 days old) by henry200 (Saint Paul MN)   |   | |
Try sliding a slender screwdriver shank (or other heavy steel rod that will fit) through the hole in the separator nut to get some additional leverage while holding the separator.
That's a nice looking D2! |
Post# 179868 , Reply# 2   5/4/2012 at 08:58 (4,368 days old) by Real1 ()   |   | |
a real rust penetrant like PB Blaster or Liquid Wrench. WD40 is nothing more than spray silicone-a water displacer, hence the initials 'WD'.
Kevin |
Post# 180210 , Reply# 6   5/7/2012 at 18:38 (4,365 days old) by dwhdarren97 ()   |   | |
I have the D2A (later dark brown version listed for wet pickup). It works awesome with the aquamate I, see my other thread on aquamate I vs II vs III. |
Post# 180219 , Reply# 7   5/7/2012 at 20:18 (4,365 days old) by floor-a-matic (somewhere)   |   | |
I think the motor needs serviced; it growls when I turn the vac off. I'll probably leave it to someone here who is experienced in Rainbow vacs? I've messed up one motor & can't afford to do it again. :( |
Post# 180324 , Reply# 8   5/8/2012 at 17:36 (4,364 days old) by dwhdarren97 ()   |   | |
Mine makes odd noises when I shut it off. Sometimes it winds down smooth, other times with vibration or squeaking. Is this a sign of dry bearings? |
Post# 181411 , Reply# 11   5/16/2012 at 21:52 (4,356 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 181462 , Reply# 12   5/17/2012 at 05:31 (4,355 days old) by dwhdarren97 ()   |   | |
Ben, does the VG I actually perform better than the II on an R-1024 F nozzle? |
Post# 181491 , Reply# 13   5/17/2012 at 10:34 (4,355 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 182055 , Reply# 14   5/21/2012 at 20:43 (4,351 days old) by floor-a-matic (somewhere)   |   | |
Were there any R-1024 PNs (the entire housing) in tan or brown? |
Post# 182085 , Reply# 15   5/22/2012 at 02:46 (4,350 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Erik,
No. The plastic shell housing was white/cream. The only variations the R-1024 PN had owed to label designs. From 1974 to 1976, the front label on the PN read "Rexair" in script, over a light woodgrain background. From 1977 to 1978, over the same light woodgrain background, the "Rainbow" script was seen, replacing the "Rexair" script. A variation of this label design had a darker woodgrain background, and was seen on all R-1024s repaired after 1981. From 1979 to early 1980, the label design changed to a solid dark brown background. In the middle were silver/yellow-orange gradient stripes, and above them was the same "Rainbow" script. The final label design, used only during the spring and summer of 1980, was a simple retreading of the 1979-style label: the silver/yellow-orange gradient stripes were now near the top of the decal, with the "Rainbow" script in the center below them. With the exception of the lower-end Roto-Matic Power Team nozzles (meaning: no automatic height adjustment), the only variant of this design with a different color for the motor shell housing was that of the TriStar Turbo Brush (cherrywood brown). ~Ben |
Post# 182485 , Reply# 17   5/24/2012 at 20:58 (4,348 days old) by williamr1248 (USA)   |   | |
Eric, I would use only about 1/2 cap full of floor cleaning concentrate in the spayer jar and fill up to top with water. The solution is very concentrated. |
Post# 250608 , Reply# 18   9/19/2013 at 00:12 (3,865 days old) by floor-a-matic (somewhere)   |   | |
I've been using the D4SE with SqueegeeMate (AquaMate with squeegee tool attached) & 4-quart basin; & the water was pitch black once the basin is full. |
