Thread Number: 16715
cord real
Post# 178307   4/24/2012 at 09:29 (4,383 days old) by kirby (passadena md)
Hi everone I really need help with this I own a hover concept one not shure what model I will take a look when I get home iright now I am at school on my breck. on this hover when i pull out the cord and press the buttton to make the cord rewind it dosent rewind. i took it apart the day i got it to revove all of the dust and junk i took it all apart and removed all of the dust and put it back togeter. no unfortunatly the machine dosent run it did not run when i got it.
can i get dsome help thanks
david kahn
Post# 178650 , Reply# 1   4/26/2012 at 11:30 (4,381 days old) by rugsucker (Elizabethton TN)
cord reel
First-CAUTION-Use care anytime you are near a CW spring!Make sure it is unwound or stay away!It will cut you in a heartbeat.--A common problem with these is worn carbon brushes and motor,next possible switch problems.If a high milage machine may not be worth major repair.
