Thread Number: 16635
Air-Way Twin-Motor lubrication points |
Post# 177384   4/17/2012 at 14:57 (4,362 days old) by truckerx (Palm Springs, CA)   |   | |
To Air-Way experts: I noticed that on the 1920's suction uprights, the motor lubrication points specify "grease." It's stamped on the motor housing. That, to me, would indicate ball bearings.
Here's the problem: I also have a later model Twin-Motor Air-Way. I took it upon myself to also grease the main motor bearings and the brush-roll motor bearings. This machine does not specify, and I don't have a manual. I assumed that both main motor and brush-roll motors use the same lubricant. After greasing both motors, the machine seemed to labor, got very warm and then began losing RPM's. Just wondering if I did the right thing? I used standard motor bearing grease purchased from a vacuum repair shop. I do know better than to grease brass sleeve bearings, as they require oil. I am wondering if the brush-roll motor and the main motor require the same type of lube or if one should have been oiled - the other greased? If any of this makes sense to you Air-Way gurus, I'd appreciate some advice. Thanks in advance. |
Post# 177404 , Reply# 1   4/17/2012 at 17:47 (4,362 days old) by Air-WayCharlie (USA)   |   | |
Bernie,
I discovered that my model 35 needed grease after Marty Kaplan pointed out it seemed kind of whiney at one of the conventions. I had completely forgotten about the grease points on both motors. We used something that someone had at the convention for the greasing. I don't remember what it was but after we did it, you could hear the motors begin to run faster and quieter. It was amazing. When I acquired the model 40, it came with all the attachments in the boxes. Included was a tube of grease for the motors. I have used that since for both vacuums with success. It is odd that your vacuum motor slowed down. I would think it would have acted like mine. I believe that someone told me sometime in the past that sewing machine oil can be used for both motors. Your vac does have the cloth wick that absorbs the grease/lubricant and it attached to the removable screw--correct? Is it possible that any of the stuff you were using got on the armature? What if you let it run for just a while? Only the vacuum motor with the swivel indicator either pointed down or at the handle. It is lined up properly to allow for full air intake, right? Just checking. |
Post# 177411 , Reply# 2   4/17/2012 at 19:48 (4,362 days old) by truckerx (Palm Springs, CA)   |   | |
Thanks for the response. Figured I'd better start a new Air-Way thread as the previous Air-Way beater-bar topic somehow morphed into Mixmasters and Butta!
I'm glad to know that both motors on the 35 take grease. That's what I had put in them. It's possible I used too much grease or it got on the commutator. What I did to temporarily remedy the problem was to remove as much grease as possible from the the lubrication ports, and squirt some WD-40 in there. Both motors immediately began to run much better and faster - then added a few drops of 3 in 1 oil and Voila! So I glean from what you're telling me that both motors have ball or roller bearings that require grease? In retrospect I may have used too much grease. The directions on the tube of grease warn not to use too much and to fill the port no more than 1/3 full. I think it's ok for now. It's running pretty well with the mixture of grease WD-40 and 3in1 oil. It's back in the closet for now, so I had to move out. Thanks for all the advice you're a damned jewel. BTW - what do you think of the new bumper I fashioned for her? |
