Thread Number: 16483
Hoover Turbopower 2, 3 And 1000 Questions |
Post# 175862   4/4/2012 at 10:54 (4,398 days old) by AlexHoovers94 (Manchester UK)   |   | |
I was lead to believe that the Hoover Turbopower 3 autosense models did not sense as well as the turbopower 2 autosense and 1000, is that true? And if so, why? Was it just because the hose was longer and it took longer for the dirt to get to the sensor? I also read somewhere that the hose on these models was far two narrow for a clean air machine and that is might of put strain on the motor, well when I took the hose off and put it back on when the machine was running it didn't sound like the motor was being restricted so is this true? I heard that these machines clog a lot, now I haven't had that problems yet but apparently that is because the dirt channels in the cleaner head were larger that the diameter of the hose so things got stuck? And finally where is the air fresheners supposed to fit? Does it go in the post motor filter cage? Any suggestions will be gratefully appreciated. Alex. |
Post# 175863 , Reply# 1   4/4/2012 at 10:59 (4,398 days old) by AlexHoovers94 (Manchester UK)   |   | |
Post# 175910 , Reply# 4   4/4/2012 at 17:34 (4,398 days old) by AlexHoovers94 (Manchester UK)   |   | |
I have heard people say that they don't know there vacuum cleaner is colgged so they take it to a vacuum shop to get repaired, well surely you would be able to tell by the difference in motor pitch and obviously it not picking up properly. Seriously why do people need to take clogged vacuums in to a repair shopwhen it is very easy to do your self. Also did hoover not realise that the hose was a bit to thin and things could get lodged in it :S but also putting strain on the motor and bag housing? The turbopower 2's were made out of abs plastic so surely it would be tuff enough to take the strain I would like to think. |
Post# 175952 , Reply# 6   4/5/2012 at 04:14 (4,398 days old) by kirbymodel2c (Nottingham, England)   |   | |
Post# 175958 , Reply# 7   4/5/2012 at 07:13 (4,398 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
